looking for a lift point diagram for a gen 1 (R52)
Old Jul 28, 2010 | 01:44 PM
Sidewalksam's Avatar
Sidewalksam
I know it sounds dumb but something like this
Also what is a reasonable service manual option for simple moderate DYI
thanks
Old Jul 28, 2010 | 01:52 PM
HRM's Avatar
HRM
Bentley manual on Amazon for $75 bucks FTW, and there a 4 jack points at about the same place as that diagram. They are very obvious once you look as they are identical rectangular pads that have no other function. They are the only points on the car.
Old Jul 28, 2010 | 01:56 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
edit: HRM beat me to it, but to reiterate,
Pretty much only on those plastic pucks under the side skirts. But, you can use a 1foot section of 2x4 and place that just behind the front puck to give you a jack surface allowing jack stands to go onto the pucks. You can find the balance between front and rear to get the entire side up at once.
If you're putting it on jack stands, put one side up on lowest, then do the other, then come back to the first and raise it a couple notches at a time. Basically go up evenly so that the car doesn't fall off.
For a service manual, I have the one by Bentley Publishers. It is very good. But the Haynes manual should be nearly as good for less.
Old Jul 28, 2010 | 02:04 PM
Sidewalksam
Thanks you are both groovie.
are there no central jack points such as an engine mount or rear support?
Old Aug 14, 2010 | 04:08 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
There are, but they are too far under the car to be of any use when jacking it up.
Old Aug 14, 2010 | 04:47 PM
ScottRiqui's Avatar
ScottRiqui
On the R52, if you have a low-profile jack you can get to a good rear support and jack up the entire back end at once. Look under the car where the cabrio-only crossbrace goes across the exhaust pipe:
Old Aug 14, 2010 | 04:52 PM
Sidewalksam
cheers scott that is one end anyways. My spyder is too low in the front so I drive it up on a few boards and then jack and stand from there.
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
