How To Interior/Exterior :: Reset scheduled maintenance
on my mini 06 it displays when the service comes do. i have changed the oil and filters but it keeps racking up miles past service. what is the procedure to reset this to zero. any help would be appreciated.
To reset the service interval indicator:
push trip button
turn ignition key to position 1 and 15A will appear to left of mileage
release trip button
wait 3 seconds
push trip button
wait (5 - 8 seconds) for RST to appear in left corner
release trip button
push trip button
15000 [or kilometer equivalent] will appear as new service interval
release trip button
The miles [or kilometers] until next service will now count down from the reset interval.
To enter the service Menu:
Insert Key (Do not press clutch / brake)
Press Start button
Wait until the Car / relevant Service symbol disappears on the Rev counter display. Immediately after the symbol goes out - Press and hold Both buttons on the Rev Counter
Continue to hold - the system Will run a dash light check.
Continue to hold.
Display will then show VIN / Menu,
Continue to hold through this until the time Reappears on the display.Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button)
After another second of 2 the display will show the Front Brake Symbol You Are Now in the Service Menu.Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Rear Brakes To Reset the warning indicator light - Press & Hold the BC Button at the relevant symbol until RESET appears - then press and hold again until the process is complete.Turn Off and On the Ignition again - Warning should now have gone.
Press Start button
Continue to hold.
Yellow,
Nice. Do I follow the instructions above (The one with out the pictures) or do I have to follow other instructions? If not, can you provide me the info? How can I scroll through the other service reminders and what else reminders are there? Thanks!
How about an '04 MCS? I have tried the following and it just goes to a test mode, so either I have the wrong procedure or I'm doing something wrong. Thanks.
Press and hold the trip odometer button.
Insert car key and turn it to the first position.
Watch for the word "RESET" to appear on the Odometer indicator.
Release the trip odometer button, then press & hold it again.
Wait for the "RESET" message to flash.
Release the button, and then press & release (once only)
The Service interval is now reset to 10,000 miles
Oil Service Re-set
Hi .... new to this forum. I have a 05 Cooper S Cabrio. Just changed the oil myself for the first time. I cannot seem to get the oil interval to reset. Can someone give me a step by step on "how to" ?
If you have an '05, the steps in post #2 should work for you. The timing can be a little bit finicky/temperamental, so you might have to try it a few times.
MC36
Jan 1, 2019 06:53 AM
vulkandino
Oct 31, 2015 08:29 PM
