electrical problem.....help please.
hello all,
since a recently fixed deer hit my check engine light was on coincident with the outside temp sensor showing -40 degrees. after the repair the front sensor was found unplugged. since replugging the check engine light has gone out and the ambient temp sensor has resumed display of proper temperature, however, an obd shows the code p0073 which translates to the problem fixed by plugging back together the disconnected wire.
will unhooking the battery reset the code?
thanks for the help.
david
david
