JCW - factory or kit?
Old Apr 22, 2010 | 07:05 PM
Bimjo's Avatar
Bimjo
How do you tell the difference between a factory JCW and a dealer installed kit? Or is there a discernible difference between the two?
Not a big deal, just curious.
Old Apr 22, 2010 | 08:27 PM
Robin Casady's Avatar
Robin Casady
They are very different internally. The factory JCW has a different turbo, different pistons, different clutch, different transmission...
All the kit has is an cold air intake, chip mod, and exhaust.
Old Apr 22, 2010 | 08:39 PM
Bimjo's Avatar
Bimjo
Thanks for the info & sorry, should have mentioned it's an R53. So, short of a tear down there's no way to tell? Just trying to get a handle on what I actually bought.
Curiosity has come close to killing me as many times as the cat.
Old Apr 22, 2010 | 08:41 PM
iceckid's Avatar
iceckid
Curiosity has close to killing me as many times as the cat.
e
I believe the best way is to have your a dealer check your vin.
Old Apr 22, 2010 | 09:41 PM
Ferroequine's Avatar
Ferroequine
That may be the only way, to pull the factory option sheet. All factory JCW's were 2006 model year builds (and 2007-2008 for the cabrio's). The factory JCW option essentially installed the same kit that the dealer could install post delivery. All factory JCW's also had the JCW big brake kit installed, which again was also available as a dealer installed accessory.
Old Apr 22, 2010 | 09:49 PM
JustinGTP's Avatar
JustinGTP
I also heard that if your car has a badge on the lower front grill, then it's a factory jcw, if it does not, it's a dealer kit. Someone correct me if I'm wrong :D
Old Apr 23, 2010 | 06:08 AM
Bimjo's Avatar
Bimjo
Thanks for the info guys.
Old Apr 23, 2010 | 06:25 AM
wildcrazy442000's Avatar
wildcrazy442000
The 1st gen. Aero kit was dealer installed. I don't think you can go by that badge. I am guessing VIN number, or window sticker is the only way.
Old Apr 23, 2010 | 09:16 AM
rkw's Avatar
rkw
The factory JCW includes JCW brakes (calipers painted red and larger than standard). However, they can also be purchased and installed separately. Realoem.com distinguishes between factory JCW and standard S, and if you enter your VIN there it should identify what it is.
BTW, badges are included with both dealer and factory JCW kits.
Old Apr 23, 2010 | 09:54 AM
Porthos's Avatar
Porthos
http://www.motoringfile.com/2008/11/...i-vs-stage-ii/
This should help you out a little
Old Apr 23, 2010 | 01:31 PM
wildcrazy442000
Originally Posted by Porthos
Except OP is asking about a R53
Old Apr 23, 2010 | 05:02 PM
Bimjo's Avatar
Bimjo
Realoem.com says it's a Cooper S, so I guess I have a dealer installed kit.
Thanks for the info everybody, you guys are great!
Dec 23, 2015 10:36 AM
Mini'mon
Aug 26, 2015 01:02 PM
ASRman
Aug 13, 2015 09:33 AM
