Shifting at high RPMs
Old Sep 16, 2009 | 08:38 AM
needcaffeine's Avatar
needcaffeine
I've noticed when at high RPMs 5,000+ if I try to up shift I cannot with a fully depressed clutch; & thus have to skip a gear or lower the RPMs. Is this normal? (I'd think for racing you'd want this)
Old Sep 16, 2009 | 09:39 AM
geekswrath's Avatar
geekswrath
I don't have this problem.
Old Sep 16, 2009 | 11:09 AM
go_mini_go's Avatar
go_mini_go
wha?
You are unable to upshift the car say from 4th to 5th with the clutch engaged over 5k rpm?
Old Sep 16, 2009 | 11:25 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
I think you might have a problem. On my way home from running errands today I gave my MINI a test. And ran up into the high 30's (6400RPM) in first gear before shifting, and had no problem shifting into 2nd. Then ran 2nd up to the speed limit of 60 (5800RPM) before shifting to 3rd, no problem.
Old Sep 17, 2009 | 09:11 AM
martinb's Avatar
martinb
Are you fully depressing the clutch? Make sure you can bottom it out. If not, move your seat up. Otherwise, you probably have some sort of problem.
Old Sep 17, 2009 | 09:20 AM
go_mini_go's Avatar
go_mini_go
Your hydraulic clutch may need bled if the clutch is not disengaging fully
Svejk
Feb 24, 2019 12:18 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Jacob Kenney
Sep 1, 2015 10:22 AM
wind715
Aug 11, 2015 07:56 AM
