Is the 07-09 JCW Shifter different from the 02-06?
Old May 18, 2009 | 03:54 PM
MrCooperS's Avatar
MrCooperS
Moderator
I recently bought a JCW shifter. I was told it's the same for all MINIs. I attempted to install this...I thought it's just a simple pull and replace. But the neck of the JCW shifter seems too small and won't fit through. Here's the pics:
Am I installing it wrong? Or is it just a different shifter?
Old May 18, 2009 | 03:57 PM
SlowGSX98's Avatar
SlowGSX98
I believe that the R56 ***** are a different size than the R50/52/53 *****
Old May 18, 2009 | 04:02 PM
MrCooperS's Avatar
MrCooperS
Moderator
Different how? Can I retrofit it to fit?
Old May 18, 2009 | 04:17 PM
SlowGSX98's Avatar
SlowGSX98
If you look here: http://http://www.whalenshiftmachine...007-_r56_knobs it explains the difference between the *****. As far as retrofitting one, I'm not sure
Old May 19, 2009 | 04:57 PM
Edge's Avatar
Edge
AdMINIstrator
Sorry, you were told incorrectly. Definitely not the same between 1st Gen & 2nd Gen.
Compare these two pages. Notice the part numbers are completely different for the R53 vs. R56:
RealOEM.com - BMW R53 Cooper S Gear shift ****
RealOEM.com - BMW R56 Cooper S Gear shift ****
Return the **** and ask for the correct one! You can even give them the exact part number from the info on RealOEM.
W0TM8
Dec 19, 2019 07:50 AM
caiken
Aug 27, 2015 06:55 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
jcb-memphis
Aug 8, 2015 11:09 AM
