Wet Okoles coming today - removing front seats?
Old May 11, 2009 | 08:28 AM
Ladidah's Avatar
Ladidah
I ordered the full set, fronts & rears, for my '06 Cabrio. They should be deliverd today, per UPS tracking. It only took 2 weeks from when I ordered! I thought it would be longer...
I have heard the easiest way to install is to remove the front seats and that it is as simple as 4 torx bolts. But I have the heated seats and I wonder about the airbag connections. Can I undo the bolts to lift the seats, but leave the airbag and the heated seats still connected? Does anyone have a picture of these connections so I know what to look for?
Any hints for the rears? I think I have figured out how to take out the bottoms.
Any other hints/tips/warnings about installing Wet Okoles?
Thanks!
Old May 11, 2009 | 03:59 PM
darmog's Avatar
darmog
I don't think you'd need to take out the front seats. It's not that difficult. I have big hands and managed enough. SOme tight squeezes but nothing unmanageable. The back seats though are a different matter. Not sure if there's a difference between the coupe and convertible when it comes to back seats, but I definitely had to take them out which is pretty simple to do. This link is what I used, but again it was for the hard top. Hopefully, it'll apply for you too.
http://www.miniacal.com/remove_rear_seats/
Old May 11, 2009 | 04:19 PM
iwashmycar's Avatar
iwashmycar
if you do take them out its just 4 torx up front. T25 i believe. I dont have heated but there was just one big connector that you pull a little black hadle and unconnect... easy
Old May 11, 2009 | 05:08 PM
4Boogie's Avatar
4Boogie
all throttle no bottle
Make sure you disconnect the negative connection on your battery before you start so you dont set off your airbags
Old May 11, 2009 | 05:15 PM
Mishka's Avatar
Mishka
You can install the front seat covers without removing the seats. The first one is the hardest since your figuring out what works as you go. I recommend raising the seat as high as possible to give you more room to work.
I installed mine without removing the seats and just had them out for cleaning this weekend and put them back without removing the seats.
Old May 11, 2009 | 07:01 PM
Ladidah's Avatar
Ladidah
Thanks! The UPS man came at 5:30 and we got right on it. Just finished up a few minutes ago.
We got them on by removing the torx screws but not unplugging the heated seats/airbags.
Getrieben
Sep 12, 2024 07:03 AM
flyers47
Jul 27, 2020 02:38 PM
bneer
Jul 15, 2019 04:41 PM
minicoclub
Aug 25, 2015 09:07 AM
