GPS Mounting
Old Apr 9, 2008 | 05:59 PM
rrcaniglia's Avatar
rrcaniglia
GPS Mounting
Has anyone found a good place to set a portable GPS? Or maybe a good way to mount a portable GPS that doesn't involve a window suction cup?
Old Apr 9, 2008 | 06:02 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Here's mine.
https://www.northamericanmotoring.co...8&postcount=17
Kuda also makes some mounts.
Old Apr 9, 2008 | 06:42 PM
rrcaniglia's Avatar
rrcaniglia
Wow! It's like an F-16 cockpit.
I've got an old-style Magellan Roadmate 700. I've set it in front of the tach on a foam pad, but that obviously isn't good.
What you're indicating is that I need to break down and buy a new unit that I can mount in a similar way.
R
Old Apr 9, 2008 | 07:07 PM
BlimeyCabrio
Hardly... you must be thinking of Sid's car...
Old Apr 9, 2008 | 07:13 PM
101101's Avatar
101101
I've got a Kuda, the one that mounts to the top of the dash between the wheel and speedo (sorry, no pictures on this computer) and like it because it puts the GPS in a very easy to see place (I don't have to look very far down to glance at it while driving in heavy traffic in unfamiliar settings). Only problem is the mount I got has a built in charger, so it kind of blocks visibility of the 30-50 mph range on my center speedo, but I normally use the digital speedometer in the tach (even before the GPS).
Old Apr 9, 2008 | 07:52 PM
rrcaniglia's Avatar
rrcaniglia
If I hadn't seen it, I wouldn't have believed it. I flew in the military for over 20 years, and I've flown aircraft not as complex as Sid's car. Tell him I think it's great!
101101, I like the idea of a more heads-up position. Did you have to punch holes to mount it?
R
Old Apr 9, 2008 | 08:40 PM
101101's Avatar
101101
Note: my MINI is an '04; based on your sig pic, it looks like your's is a 2nd gen.
The Kuda mount for mine has two flat pieces of metal; the lower one just slides between the soft dash pad and the plastic front; the upper tab goes under the vent in the dash. The only hole I had to make was a small one (~2 mm) to run the wire for my powered base; if you don't get the powered base, don't mind a wire hanging down, or find some creative way to route that wire no holes required.
I just looked up the install directions for a 2nd gen on the Kuda site and it doesn't appear to require any holes, you just need to be a little brave as you have to pop off a cover (you may have no issue doing this; I wouldn't. Then again, I've pulled out the entire interior of my car to install an amp and run wires cleanly) - doesn't look too difficult; probably could be done in <30 min if you take your time.
Old Apr 9, 2008 | 09:14 PM
MLPearson79's Avatar
MLPearson79
I actually use the window suction-cup thing for mine, but I mount mine in the very lower left-hand corner of the windshield. Within easy reach, but still out of the way, and I was able to run the cord down in the seal from the A-pillar to the parcel shelf, underneath and over to the power adapter (I have a Garmin Nuvi 680 which has the MSN features, and the receiver for the MSN is built into the plug-in end of the cord, so I can't hardwire it - or at least so far I haven't figured out how without losing the MSN).
Old Apr 10, 2008 | 05:00 AM
BlimeyCabrio
Well... technically mine isn't hardwired, I guess... but I got a pair of extra power outlets from newministuff.com that tie into the audio harness behind the headunit... I run my GPS power cord back behind the parcel shelf and plug it in... so it LOOKS hardwired, but it still has the end on it (I don't have the MSN direct one yet, but should work for that one, too).
Old Apr 10, 2008 | 05:09 AM
Minidrivr's Avatar
Minidrivr
I use a cup holder mount or a mount I made using the ashtray for a handheld GPS.
Old Apr 10, 2008 | 06:49 AM
gjhsu's Avatar
gjhsu
I mount mine on the left side, right above my registration/inspection stickers. In the field of vision, but not blocking much.
Old Apr 10, 2008 | 07:00 AM
Ex-Pat Brit's Avatar
Ex-Pat Brit
Pro-clip has released a mount for the R56 finally, that might be a good solution for you
Old Apr 10, 2008 | 07:52 AM
VelvetFoot's Avatar
VelvetFoot
Bean bag for me leaned up against the driver's side A piller.
No sign when removed.
Old Apr 10, 2008 | 09:44 AM
Brewmeister's Avatar
Brewmeister
I mounted a spare (modified) Garmin mount right to the dash... http://tiermini.com/?p=108
Old Apr 10, 2008 | 10:06 AM
lacning74's Avatar
lacning74
Here's the link to my Kuda install.
Old Apr 10, 2008 | 10:10 AM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
Ditto - that is what we ordered. Works great for the portable NAV and the Sirius Radio.
Donna
Old Apr 10, 2008 | 10:21 AM
Bilbo-Baggins's Avatar
Bilbo-Baggins
I suction cup my Garmin Nuvi right to the upper right of the speedo. It covers the 100 - 125mph range. I don't use that part of the range too much during the week
Keeps it convenient for both the driver and passenger.
Old Apr 10, 2008 | 03:09 PM
k6rtm's Avatar
k6rtm
Another vote for the Garmin suction cup on the speedo -- I've got a Kuda mount, but it needs to handle multiple units, and I'm still prototyping brackets. But until that's done, the suction cup works great.
You can pick up a Nuvi 660 on Amazon or on eBay for $330 or thereabouts -- not too bad.
Old Apr 10, 2008 | 04:29 PM
playtowin's Avatar
playtowin
I installed the OEM Garmin mount for the Nuvi 360. It sits just to the left of the tach and comes with a harness that provides power.
Old Apr 10, 2008 | 08:30 PM
ATCQL's Avatar
ATCQL
Mine is placed the same as velvets with a bean bag,and i like the set up completly.Q
Old Apr 11, 2008 | 07:45 AM
101101's Avatar
101101
To those using bean bags: do you have issues with the GPS flying when you accelerate / brake / turn? That'd be my only concern with using such a method.
Old Apr 11, 2008 | 08:17 AM
VelvetFoot's Avatar
VelvetFoot
Well, if I don't know where I am, why am I flying around corners?
But seriously, I don't drive that fast and it hasn't flown off.
Leaning it up against the pillar helps.
Old Apr 11, 2008 | 07:58 PM
ATCQL's Avatar
ATCQL
I have never had a problem,plus the bag sits on a dash cover,Q
Old Apr 12, 2008 | 11:34 AM
MBR's Avatar
MBR
I use the suction cup that came with my GPS.
Here's how it looks...
https://www.northamericanmotoring.co...hp/photo/48190
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
minimofo
Sep 30, 2015 12:26 AM
TREX
R58 :: Coupé Talk (2012+)
Sep 5, 2015 02:59 PM
Sep 4, 2015 02:34 PM
