CUSTOM trailer
Old Jan 8, 2008 | 08:26 AM
  #26
ScottinBend's Avatar
ScottinBend
I love the spoiler too ! !
Nice project. This is something I have considered because of my 3 hour drive to my "local" track.........
Which hitch are you using?
Old Jan 8, 2008 | 11:42 AM
  #27
DixonL2's Avatar
DixonL2
Hey Dixon, is that a camper too?
No, Wish it was but it's just a box with a roof. I've seen popup campers that small though; they're pretty cool. I use mine for general hauling, also for bringing the tent, bikes etc. with our family when we tent camped. We have a popup for behind the MiniSupportVehicle now, but once the kids are on their own, we'll probably go teardrop...
Old Jan 8, 2008 | 11:49 AM
  #28
COR BLMY's Avatar
COR BLMY
My son and I made our hitches ...
I just happen to still have all my templates
Old Jan 8, 2008 | 07:12 PM
  #29
ScottinBend
Does yours go thru the back-up/fog light?
Did you do your own welding/fabing of the hitch? (I have no experience with welding)
Old Jan 8, 2008 | 09:00 PM
  #30
jasonsmf's Avatar
jasonsmf
Sharp looking trailer COR BLMY, I used to have one similar! I can't see how you are attaching the safety chains, but a wise man once told me that in the event of a freak accident, it's not a good idea to attach them to the ball mount....
Be careful out there guys!
Jason
Old Jan 8, 2008 | 09:03 PM
  #31
AutoXCooper.com's Avatar
AutoXCooper.com
How did that happen?
Old Jan 8, 2008 | 10:40 PM
  #32
COR BLMY's Avatar
COR BLMY
OUCH.
Either a ball came off or the pin came out ... and that had a lot of tounge weight. Hard to tell from the carnage.
I made mine with 1/4 plate (bigger than anyone avaliable, 2" cross member) and do have a chain system.
I also am one of the few folks that pull a trailer at or just above the 55 CA limit.
Good caution though ...
Old Jan 9, 2008 | 04:05 AM
  #33
jasonsmf's Avatar
jasonsmf
I'll probably never know exactly what happened, the ball mount was nowhere to be found afterwards. The best I can guess is that the pin parted ways somehow, although thats not something that one typically sees. The trailer was loaded carefully, tongue weight was just about where it should be. The front of the trailer is folded up from when it ramped up the center concrete wall, which launched the trailer up above the car in the air. The trailer tumbled three or four times across the highway before coming to rest. The problem with our setup was that with the chains attached to the ball mount, once the pin came out the chains were worthless. I knew this was not the best way to do things, but never did I imagine that we'd have a failure in this way. My new setup will take the chains to the chassis somewhere.
Jason
Old Jan 9, 2008 | 04:48 AM
  #34
DixonL2's Avatar
DixonL2
I've got the MDM drawbar/hitch, and the chains do attach to the drawbar. There aren't really any great places to attach the chains there in back, so it's a "one point of failure" system. Even being really careful with the pin, I can see where metal fatigue on the pin retainer, or a careless install, could cause the same problem with mine. I'm a'gonna take a look around there underneath and see what I can find. A little ingenuity should come up with something!
Old Jan 9, 2008 | 07:07 AM
  #35
jasonsmf's Avatar
jasonsmf
I'm thinking of welding a tab onto the drawbar further back on the square tube part that will be behind the bumper and also welding a tab onto the actual hitch frame itself. A small length of chain or cable between the two tabs can then work as a safety chain to hold the drawbar in the event of pin failure/loss. I will continue to use the normal trailer safety chains to the drawbar (MDM style), but the drawbar itself will be safety chained to the car, hidden behind the bumper. It will be a little bit of a hassle to attach, but a lot less hassle than being stranded in St Louis with a balled up trailer.
Jason
Old Jan 9, 2008 | 08:41 AM
  #36
AutoXCooper.com
Originally Posted by jasonsmf
which launched the trailer up above the car in the air. Jason
Was there any damage to the MINI? Pics?
Old Jan 9, 2008 | 09:04 AM
  #37
jasonsmf's Avatar
jasonsmf
No damage to anything other than the trailer, height wise it was above the MINI, but it was still rearward from the car. Thankfully, all other traffic on the road was able to miss the trailer and nobody was injured.
I am very glad that I went overboard when I designed the tire rack on this trailer, had I only used a couple straps holding the tires on as I used to, I'm sure we would've had Kumho's all over the highway.
Jason
Old Jan 9, 2008 | 10:15 AM
  #38
COR BLMY's Avatar
COR BLMY
the bike racks have 2 mounting points attached to the frame and come through the rear "vents"
2 eylets there and youy have a place to connect chains ...
totally independant of hitch, pin,ball.
Last edited by COR BLMY; Jan 9, 2008 at 05:08 PM. Reason: I HAVE NO LETTERS ON MY KEYS & I CANT SPELL !
Old Jan 9, 2008 | 10:57 AM
  #39
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Originally Posted by COR BLMY
Thanks ...
hey that is a +1 splitter and a +1 wing extensoin in the photo
both the new material and style ...
That looks amazing...can't wait.
Old Jan 9, 2008 | 01:35 PM
  #40
DixonL2's Avatar
DixonL2
VERY cool idea, have to find a way to keep it from rattling, so chain is out. Maybe a strong, fender-washer-backed eye bolt on either side of the battery box? Nyah, that'd be ugly and invite rust. Hmmm...
Old Jan 9, 2008 | 03:06 PM
  #41
jasonsmf's Avatar
jasonsmf
Buy a Magnaflow like me, huh?? what rattle???
How about some of that plastic coated cable?
My thoughts were to limit my modifications to the hitch itself so that I always have the option to return my car back to completely stock.
With all this talk, I need to stop thinking and start doing!
Jason
Old Jan 9, 2008 | 08:59 PM
  #42
DixonL2's Avatar
DixonL2
I definitely like that cable idea though... I'm wondering what temps that hitch is really exposed to and whether it'd melt that vinyl inside the 1 1/4" hitch receiver tube, that'd be ugly.
I wonder if one were to run a "wye" cable while the hitch is off the car, attach cable to the bumper mounting bolts and run to the hitch tube, with a clip-type device to attach to the drawbar only when it's in. Heck, run stainless cable and you wouldn't need worry about rust or rattle if it's done right. Hmmm.
By the way, Jason, do you recognize this guy? Looks like we're doing the Winter Driving school again, block off February 24... I'll bring my trailer... with my now-bald runflat "track tires"... and my big-a aluminum floorjack if you don't want to haul yours along...
Old Jan 10, 2008 | 06:31 AM
  #43
BoCRon's Avatar
BoCRon
I made one to haul the EZ Up and other stuff to track days. I had a great time making in and have used it quite a bit.
Annette
Old Jan 10, 2008 | 12:08 PM
  #44
jasonsmf's Avatar
jasonsmf
It doesn't get all that hot in there, warm yes, but nothing to write home about. When not in use, my trailer wiring harness gets tucked into the opening for the drawbar. As long as I don't touch the exhaust (OUCH!!!!) I can reach right up there and grab the hitch immedately after shutting off the engine.
not a bad idea
My little bro had a blast flogging my car around the Wilson Circuit that day! I love that picture!
See you on 2/24!
Jason
Old Jan 10, 2008 | 07:23 PM
  #45
DixonL2's Avatar
DixonL2
Jason: I think I'll do a little less driving this year and take a few more pictures, that was a blast. Learned a good bit too...
Old Jan 11, 2008 | 06:11 AM
  #46
paulgraz's Avatar
paulgraz
I'd really like to get one of these trailers, but they're kinda pricey:
Mfg's website: http://www.pulmor.com
Old Feb 11, 2008 | 07:58 PM
  #47
COR BLMY's Avatar
COR BLMY
My son made this for both of our hitches ...
So when not trailering we have tow hooks ...
Old Feb 11, 2008 | 08:14 PM
  #48
Duck360198's Avatar
Duck360198
I love it! Makes me smile!
Old Mar 12, 2008 | 04:31 PM
  #49
kbleicher's Avatar
kbleicher
What are you guys using for the hitch itself? Easily self installable? Work on a clubman?
Old Mar 12, 2008 | 04:51 PM
  #50
NashvilleMiniStan's Avatar
NashvilleMiniStan
Trailer looks good, however the MINI looks Great.
