MINI maintenance
Old Nov 24, 2007 | 03:57 PM
djmini420's Avatar
djmini420
MINI maintenance
Hey guys new to the forum and looking to buy a used mini cooper s 02-05. Just curious on how much maint. these babies need. like when do u have to replace clutch, brakes, etc. Thanks
Old Nov 24, 2007 | 04:57 PM
hemiheaded18's Avatar
hemiheaded18
Brakes seem to go at about 40-55k miles. Clutch should last as long as its not abused. Oil is synthetic so thats about the biggest cost item that will build up over time. Typical oil change is about 35-40 in parts. 5 quarts Mobil 1 and a Purolater is I think 33-34. Fuel filter and PCV are not serviced. Neither is timing chain. If its over 50k, check brakes. Also check plugs, I changed mine at about 48.
Old Nov 24, 2007 | 10:07 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
If brakes are abused they won't last long, go figure. My stock brakes only lasted 18k, the pads were gone and the rotors were deemed unturnable due to wear.
More things to check: after 40k, the fuel filter. I have heard recomendations on transmission fluid change at 50k--I think--as well. The engine belt needs to be inspected for cracks or seperating. Not sure on the interval. Wheel bearings should last well over 100k. The dampers might loose some dampening ability after about 60k. Stock rubber bushings on the older cars might start to degrade and crack due to age. New OEM replacements would last upwards of 5 years.
Am I forgeting anything?
Old Nov 28, 2007 | 12:44 PM
djmini420's Avatar
djmini420
Hey guys thanks for the info.. I think i found my mini =)
Old Nov 28, 2007 | 04:31 PM
beken's Avatar
beken
Other than a few nit picky warranty items at the beginning, my 05 MINI's only been in for routine scheduled service. Oil changes and Inspection services. I keep thinking it might be time for brakes pretty soon but they seem to be holding up fine.
If you do the inspection service as indicated, they should be able to find all the things that might be wrong with your car. The last inspection service I did, they replaced the wiper blades.
If your car is in good order, it should give you lots of reliable service.
Dec 23, 2015 10:36 AM
tr3y003
Oct 22, 2015 10:48 AM
ludedude
Aug 10, 2015 07:16 PM
PelicanParts.com
Aug 7, 2015 08:39 AM
