Requesting pics of aggressive MINIs
Old Oct 24, 2007 | 03:14 PM
  #101
works4me's Avatar
works4me
Couple more pics
You can see it a bit better in these pics...
And yes, I am *catching* the Z8
Old Oct 24, 2007 | 03:21 PM
  #102
works4me's Avatar
works4me
Originally Posted by TRACE
BEAUTIFUL Mini you got there!!! Again, I keep looking at your MINI more than the AM - definitely fits the name of the post.
Why are you using spacers? Reason being, I'm ready to setup my MINI with Outmotoring Coilovers, and according to OM, no problem fitting 225s with 40mm offset, moreover, there will be no inner rubbing as well.
No I don't *need* to use spacers. But running larger spacers in the front than in the rear helps to reduce understeer and provides more stability at high speeds. However I *strongly* recommend using a stud conversion kit if you use spacers...
ok, and it looks cool...
Old Oct 24, 2007 | 03:26 PM
  #103
Jenn B's Avatar
Jenn B
Old Oct 24, 2007 | 03:32 PM
  #104
TRACE's Avatar
TRACE
Great to hear your tires do not rub w/o spacers!!
I searched this thread, there are only few running 225s, I think most claim if they go wider than 215s, it will rub the control arm or springs.
Old Oct 24, 2007 | 03:35 PM
  #105
TRACE's Avatar
TRACE
Originally Posted by Jenn B
JEN,
You do know in some states it's illegal to have a beautiful MINI and a beautiful smile.
Old Oct 24, 2007 | 03:38 PM
  #106
Tüls's Avatar
Tüls
Turbius Maximus
Old Oct 24, 2007 | 03:40 PM
  #107
Tüls's Avatar
Tüls
Turbius Maximus
Old Oct 24, 2007 | 03:43 PM
  #108
works4me's Avatar
works4me
Keep in mind that whether or not you need spacers depends on the wheel offset. These SSR's are definitely different than the BBS wheels I had before. If I had run this tire size on the BBS wheels (which I didn't), I would probably have needed spacers no matter what.
Old Oct 24, 2007 | 03:50 PM
  #109
TRACE's Avatar
TRACE
Got it! Thanks man!!
I know OM said, just stay away from 45offset, and you will be fine w 225s, BUT only linear coilover springs are able to accommodate the wider tires, with standard springs you will definitely rub inner area.
Old Oct 25, 2007 | 11:40 AM
  #110
yellowtruck61's Avatar
yellowtruck61
great looking car's in here. I was wondering if anyone knew how to do a grill like this. I've seen them on here and i love the look.
Old Oct 25, 2007 | 11:56 AM
  #111
cooper99's Avatar
cooper99
Do you mean the black oem aero grill kit for the MC?
http://www.outmotoring.com/mini-coop...conversion_kit
Old Oct 25, 2007 | 12:06 PM
  #112
rhubbard's Avatar
rhubbard
The grill yellowtruck's talking about is the the M7 grill, not the OEM aero grill.
Old Oct 25, 2007 | 01:06 PM
  #113
yellowtruck61
thats it. thanks man.
Old Oct 25, 2007 | 01:43 PM
  #114
Jenn B's Avatar
Jenn B
That is an M7 grill. Well, the upper and middle... the lowest part is stock.
I had the M7 grills on my 2nd MINI and aero grills on my first.
M7 is metal, aero is plastic. The M7 is a lot more open. M7 is far easier to install though it costs a lot more so it depends on what you can spend and how much effort you want to make.
Aero grill on my 04
M7 grill on my 06
Old Oct 25, 2007 | 01:59 PM
  #115
yellowtruck61
Aero grill on my 04
M7 grill on my 06
i've got a stock Cooper and i have been looking at these. The Aero grill is probably what i'll go with since it's cheaper. I gotta do what i can to make it slightly meaner.
thanks.
Old Oct 25, 2007 | 03:19 PM
  #116
Jenn B's Avatar
Jenn B
There are a few how-to's on here. It requires a little dremmel action but looks really great when done. The part in the hood fits perfectly, the middle needs a trim.
Old Oct 30, 2007 | 06:58 AM
  #117
checkmate2006's Avatar
checkmate2006
Jeepers after 300+ mile trip
Old Feb 16, 2013 | 02:51 PM
  #118
maxmini's Avatar
maxmini
This thread has been dead and buried for awhile . I had soem current pics taken recently , lets see what else is out there .
Randy
Old Feb 16, 2013 | 03:01 PM
  #119
MSFITOY's Avatar
MSFITOY
Hey Max...10 years and still rockin!
Old Feb 16, 2013 | 05:28 PM
  #120
maxmini's Avatar
maxmini
Lookin good as usual . Throw up a shot of that old honda of yours that car is still stuck in my head
Randy
Old Feb 16, 2013 | 05:49 PM
  #121
MSFITOY's Avatar
MSFITOY
Just for you Randy
Old Feb 16, 2013 | 05:56 PM
  #122
maxmini's Avatar
maxmini
Just for you Randy
Ive never even owned a Honda but if i did it would look as close tothat as possible
emulajavi
Dec 24, 2018 09:15 AM
The_Kid
Cincinnati MINI Club
Aug 4, 2016 02:40 PM
marendt428
Feb 25, 2016 07:13 AM
nomar116
Aug 12, 2015 05:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
