Ultimate Oil
Old Aug 29, 2007 | 06:48 AM
Ex-Pat Brit's Avatar
Ex-Pat Brit
Ultimate Oil
About to do Smudge's first oil change (3500 miles). Is there a "best oil" for the R56 MCS. I would say money is no object, but obviously it is.
There is no track time expected, just day-to-day use
Thanks in advance
Old Aug 29, 2007 | 06:50 AM
Loony2N's Avatar
Loony2N
I use MINI's recommendation., Castrol synthetic.
Old Aug 29, 2007 | 07:11 AM
ScottinBend's Avatar
ScottinBend
Any of the top brand synthetics are recommended. I use Mobil1.
Old Aug 29, 2007 | 07:15 AM
Loony2N's Avatar
Loony2N
Recommended by who? Personally, I don't think it matters, as long as you use a top brand, but MINI recommends Castrol (if you look at the label by the dipstick) and Mini Oil (if you look on the top of the motor) for the R56 anyway.
Old Aug 29, 2007 | 07:19 AM
Ex-Pat Brit
What I meant was, is there something better than MINI's recomended oil, but thanks for the input
Old Aug 29, 2007 | 07:44 AM
jakay11's Avatar
jakay11
I used to swear by Mobil1, but they've since changed their formulation, and I no longer am totally loyal to it anymore...
Old Aug 29, 2007 | 07:45 AM
Loony2N's Avatar
Loony2N
LOL. Of course, that is opinion, which I am sure you will get a lot of.
Old Aug 29, 2007 | 07:49 AM
Mini Works's Avatar
Mini Works
I use MOTUL 5W40 or ELF 5W40
Old Aug 29, 2007 | 08:58 AM
tennis_man's Avatar
tennis_man
If money is no object, then I would use Red Line motor oil.
Old Aug 29, 2007 | 10:12 AM
Bhatch's Avatar
Bhatch
All my cars, street or track get MOTUL 8100 5w40.
EDIT:
Link
http://www.turbolubricants.com/products_auto.php
http://www.turbolubricants.com/Motul_TECH/Car%20engine%20oil/8100%20X-cess%205W-40%203682%20(GB).PDF
Also they have a BMW Long-Life 01 Oil grade, 5w-30..the flash point is the same as the 8100 but it is less viscous at 100degee C.
http://www.turbolubricants.com/Motul...228%20(GB).pdf
Old Aug 29, 2007 | 10:40 AM
Gromit801's Avatar
Gromit801
I just started using Castrol Syntec 5w-50 Full Synthetic with a NAPA oil filter. The NAPA filter is constructed better than the OEM version.
Old Aug 29, 2007 | 12:01 PM
nanonanu's Avatar
nanonanu
I've only had my MINI for a little over three weeks now, so I've got a ways to go before my first change, but I ran only Castrol 10-30 conventional oil in my 1998 Honda Civic (which I bought in 2000), and when I traded it in for my MINI, it had 250064 miles on it, and was still running perfectly...true, it's a Honda, but still, pretty impressive.
Of course, I'll be running synthetic in my MINI, and while my 15000 mile change is covered by the maintenance plan, I'm thinking of changing it myself at 7500 "just because" it's the first change - no question in my mind, I'll be using Castrol synthetic.
Old Aug 29, 2007 | 05:43 PM
ScottinBend
Huh???
Isn't that what I said.........pick a name brand synthetic.
Must be spending too much time online reading NAM posts............
Old Aug 29, 2007 | 05:50 PM
Crashton's Avatar
Crashton
I use Mobile 1 in all our vehicles & have for 20 years. It's been good to me. No problems with it for me.
Old Aug 29, 2007 | 06:45 PM
kapps's Avatar
kapps
Just as an FYI, BMW/MINI 5w-30 is not the same as Castrol Syntec 5w-30. The MINI oil has much higher specifications. I haven't checked lately at the dealer but I'm pretty sure it's actually priced competitively. If your near by, it might be something to check out.
Old Aug 29, 2007 | 07:16 PM
Robin Casady's Avatar
Robin Casady
I decided to stick with the MINI branded oil from the dealer, based on hearsay on this forum. The following is what I've picked up from several threads here. It may be true, it may not.
The MINI branded 5-30 oil is a formulation of Castrol synthetic, but rumor is that it is formulated to a European spec. which is heavier than USA 5-30.
Mobil has two Mobil 1 oils. Mobil 1 and Mobil 1 Extended. Those used to the old Mobil 1 are used something closer to Mobil 1 Extended. The Extended version is the only one recommended for 15,000 oil change intervals, so probably the only one that would be close to the MINI recommendation.
I found that MINI oil from the dealer is less expensive than the regular Mobil 1 from an auto supply store.
Old Aug 29, 2007 | 09:07 PM
Dubaian's Avatar
Dubaian
do we have to change the oil when it reaches 3500.. mine is 3331 now.. hmmm or wait till the service?
Old Aug 30, 2007 | 07:42 AM
Mr.GBMiniGirl's Avatar
Mr.GBMiniGirl
BMW will tell you to wait until the service light says to change it. From the 4 Minis that we have owned and run I'd suggest a change every 5000 miles. The dealership will use Castrol Synthetic MINI oil. We use AMSOIL 5W30 full synthetic in all our Minis. Never had any issues!
Old Aug 30, 2007 | 07:49 AM
Loony2N's Avatar
Loony2N
What I have found, based on numerous threads in NAM is that no-one has had a problem using either the oil or the service intervals recommended by MINI. The few actual oil tests I have seen confirm there is no reason not to do so. So, if you want to spend the money and the time, it's purely a personal preference.
Old Aug 30, 2007 | 09:16 AM
thulchatt's Avatar
thulchatt
Probably does not matter that much which oil you use as long as it meets the min requirements. Most failures are not related to the oil.
I even heard a guy on Car Talk one time asking if he should change his oil after 105,000 miles. He had a Honda Civic which he just checked the level and kept going. The advice was to continue.
Old Aug 30, 2007 | 11:36 AM
Kimberely's Avatar
Kimberely
Castrol recommends these for the MINI
Engine Oil
Castrol GTX
API*,SL 5W-30 - Maximum Protection Against Viscosity and Thermal
Castrol GTX High Mileage
API*,SL 5W-30 - For Engines with Over 75,000 Miles
Castrol SYNTEC
API*,SL 5W-30 - Outperforms ALL Leading Motor Oils
Castrol SYNTEC BLEND
API*,SL 5W-30 - Added Protection for Frequent Short Trips
Castrol SYNTEC
API*,SL 5W-40 - Outperforms ALL Leading Motor Oils
Old Aug 30, 2007 | 02:11 PM
kapps's Avatar
kapps
For off-the-shelf Castrol, I'd use Syntec 0w-30 (German Castrol). Available at Autozone. It has BMW LL and VW certification, plus it's a thick 30 weight.
Old Aug 30, 2007 | 03:48 PM
korby's Avatar
korby
Originally Posted by Kimberely
Engine Oil
Castrol GTX
Castrol SYNTEC
Castrol SYNTEC
So did I just screwup by toping off with a half quart of mobil 1 ?
Old Aug 30, 2007 | 03:57 PM
Crashton's Avatar
Crashton
OH MY GOD!!! Yes you did!!!
I'll take your ruined MINI off your hads for 20% of book value. Only because you're a 5th gear NAM menber.
Oh heck korby, don't worry it's OK. You did zero harm.
Old Aug 30, 2007 | 11:43 PM
Tilen's Avatar
Tilen
Could anyone elaborate on 0W-30 oil. I cannot decide what to pour in. You could for the 0W-30 or 5W-30 Castrol SLX IV (this is the best oil money can buy; don't know if it is on sale in USA). My engine has a bit over 100.000 km and don't know if the 0W-30 is still suitable for the engine. Any thoughts?
Thanks!
