Ultimate Oil
Old Dec 15, 2007 | 07:24 AM
  #26
javelina1's Avatar
javelina1
Originally Posted by Kimberely
Engine Oil
Castrol GTX
API*,SL 5W-30 - Maximum Protection Against Viscosity and Thermal
Castrol GTX High Mileage
API*,SL 5W-30 - For Engines with Over 75,000 Miles
Castrol SYNTEC
API*,SL 5W-30 - Outperforms ALL Leading Motor Oils
Castrol SYNTEC BLEND
API*,SL 5W-30 - Added Protection for Frequent Short Trips
Castrol SYNTEC
API*,SL 5W-40 - Outperforms ALL Leading Motor Oils
The specs of the oil are what counts. Look for ACEA A3/B3 AND BMW LL-01. The only Castrol oil that meets that here in the US is German Castrol 0W-30, (and the OEM fill we get in the car when it was purchased). When you buy the 5W-30 Castrol from the dealership, it only indicates the ACEA A3/B3 spec. Not the BMW LL-01.
Mobil 1 0W-40 also meets teh ACEA A3/B3 & BMW LL-01.
Old Dec 15, 2007 | 08:14 AM
  #27
sprp85's Avatar
sprp85
don't use crappy made in usa castrols..
German Castrol all the way.
Cheaper than mobil 1 cheaper than royal, cheaper than most of other so called 'good' oils.
Old Dec 15, 2007 | 11:19 AM
  #28
Robin Casady's Avatar
Robin Casady
On the "MINI Full Synthetic Motor Oil" available at dealers, don't you think the lack of "BMW LL-01" on the label could just be a labelling issue? I'd be very surprised if the oil MINI dealers recommend and sell does not meet their own standards for their recommended service intervals.
Old Dec 15, 2007 | 11:35 AM
  #29
javelina1's Avatar
javelina1
Could very well be. At "bob's the oil guy" website, they gave the BMW dealer oil 5W-30 good marks. Better than the US 5W-30 you find "off the shelf".
I do use the dealer supplied oil. When I take the MINI in for a free oil change. But I generally keep that oil for around 4-5K miles, then change it out with the GC 0W-30.
No confirmation, but I've heard the dealership buys their 5W-30 in the large barrels, (55 gallons), and it's the European blend. (With both specs). In Europe, you can buy 5W-30 which clearly lists both specs on the bottle. Just not here!
Old Dec 15, 2007 | 02:42 PM
  #30
Bhatch's Avatar
Bhatch
i changed my oil to MOTUL 8100 Excess 5w-40 today.
at 3000 km's.
There was small metal bits in the oil and the filter after brake in, would this cause issues in the long run? I guess i will never know.
Old Dec 15, 2007 | 02:47 PM
  #31
Robin Casady
In another thread, someone with a bottle of BMW branded oil said that (like the MINI branded oil) it did not mention the BMW LL-01 rating. So, I suspect it is just a labeling issue. Perhaps they assume that everyone would understand that their own oil meets their own specs.
Both the MINI branded and BMW branded oil bottles say Made in the USA from domestic and foreign components.
Old Dec 15, 2007 | 04:26 PM
  #32
howsoonisnow1985's Avatar
howsoonisnow1985
Redline Power Pak
Old Dec 15, 2007 | 07:24 PM
  #33
Robin Casady
Originally Posted by howsoonisnow1985
Redline Power Pak
Is there an ACEA rating for Redline 5W30? I couldn't find one.
Old Dec 15, 2007 | 08:51 PM
  #34
kapps's Avatar
kapps
I don't have a bottle in front of me at the moment but Redline is definitely at least ACEA A3/B3.
Old Dec 16, 2007 | 03:54 AM
  #35
ScottRiqui's Avatar
ScottRiqui
Originally Posted by LynnEl
What I have found, based on numerous threads in NAM is that no-one has had a problem using either the oil or the service intervals recommended by MINI. The few actual oil tests I have seen confirm there is no reason not to do so. So, if you want to spend the money and the time, it's purely a personal preference.
Actually, I've had three oil analyses done (with a fourth coming up next month), and I don't think the factory/dealer oil is suitable for much more than 10k-12k miles. That's for my R53, though - I haven't seen any results from the new direct-injection engine, although the DI engines from some other manufacturers (Audi,VW) have recently been shown to be *really* hard on oil, even top-notch synthetic stuff.
sevin
May 2, 2026 06:11 AM
gmcnaugh
Oct 27, 2018 03:42 AM
CardinalsRule
Jun 11, 2016 04:34 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
