Turning off the A/C
Old Aug 17, 2007 | 08:05 PM
cadfael_tex's Avatar
cadfael_tex
Turning off the A/C
Was told many years ago by a mechanic that if you turn off your A/C before starting your car that it would help the engine last longer. Something about the extra pull on the engine at start-up from the compressor being harder on the motor. Another mechanic later said that all I was doing was wearing out my switches. So which is it?
Old Aug 17, 2007 | 08:56 PM
JustJAY's Avatar
JustJAY
I turn everything off before turning off the car. I don't see why you need to have the AC, radio, and other stuff on before you start up.
Old Aug 17, 2007 | 10:52 PM
El_Griton's Avatar
El_Griton
so I can be cold, deaf, and well lit.
jk, but for reals, when its 105 degrees out, windows down quick and ac is needed!
Old Aug 18, 2007 | 12:47 AM
ScottRiqui's Avatar
ScottRiqui
It won't make a difference one way or the other. The A/C compressor has an electromagnetic clutch to engage/disengage it, and that clutch is disabled during engine cranking to reduce the load on the starter and battery. All cars do this to some extent. I've had cars where the radio, headlamps, vent fans, and A/C are all disabled while the engine's cranking.
Ideally, the only things powered while the engine's cranking would be the stuff that's actually necessary to start the engine (ECU, ignition coil, starter, etcetera), but depending on the car, smaller loads like dome lights, parking lights, and the radio are often still powered while the starter's engaged.
Old Aug 18, 2007 | 04:38 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Yeah, I'm with Scott on this one. Definitely this stuff mattered on my 1968 Ford Galaxy. Now, not so much... I spend those neurons worrying about stuff that matters... like where my next UJ is gonna go...
rob&JCW
Feb 21, 2018 02:41 PM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Oct 9, 2015 11:12 AM
doug5g
Sep 2, 2015 04:53 PM
Suspension Products
Sep 2, 2015 10:32 AM
