HELP! Rally Driving Lights - should I or shouldn't I
Old Jul 6, 2007 | 01:27 PM
  #26
chows4us's Avatar
chows4us
Originally Posted by kgdblu
That's kinda scary. I don't want to see you behind me
Do you like the driving lights and fogs lined up like that?
Old Jul 6, 2007 | 01:50 PM
  #27
Mini S Pilot's Avatar
Mini S Pilot
Originally Posted by MDK
Cruising the GWR was a good idea- I think just about every combination was there! I was talking to the guy behind me-who was driving the Green/White classic Mini about the Shelby. I mentioned that anywhere else people would be surrounding that car but here-no one noticed as we were all way too busy checking out everyones mods and lining up for free Red Bull.
We were glad we didn't get the usual crowd around the car. We were there to try to check out all the Minis and get some ideas about what we did and didn't want on one if we ordered. We were able to answer a few of our own questions with our own eyes, chat with Mini owners, and meet a really nice group of people. We zipped off to check out a used Mini that we heard was at one of the Hall dealerships, but it wasn't even close to what I wanted. We returned to the GWR gathering in time to see my husband's bother's girlfriend just make the cut off to be included in the lineup. I took a few pictures as everyone passed by us to make the run. It looked like everyone was having a blast to say the least. I can't wait to join in the fun soon.
Thanks for you all who are giving your advice and opinions with this issue. I have a few weeks while waiting for my car to change the rally light part of the order.
Old Jul 6, 2007 | 03:23 PM
  #28
#20Works4me's Avatar
#20Works4me
My PIAA 520 set up cost $200 with brackets Wired it myself. They are also 6 1/4" in diameter which is considerably larger than OEM and they are bright
Old Jul 6, 2007 | 03:37 PM
  #29
lhoboy's Avatar
lhoboy
Originally Posted by Bullet2006
Get them! as they really set off the new Mini's! The lights will be tied to your high beams... Not to worry, all you have to do is locate the relay and change the high beam input wire with a ignition on power wire and you are set to go. ( I just did this with my 2004 MCS MC40 a few day ago... Although mine is not a 2007, the wiring should be very close if not identical) There's my 2 cents! I hope it helps!
I'm not certain on the 2nd gen MINI, but on the first gen you can operate the driving lamps independently of the headlamps by depressing the driving lamp button for a couple of seconds. Try that on your '07s.
Whoops! Ignore that. The reason that works on mine is that I have Ian Cull's auto armed driving lamp relay installed.
Old Jul 6, 2007 | 03:39 PM
  #30
lhoboy's Avatar
lhoboy
Originally Posted by Crashton
If you like them get them. IMO the factory rally lights on either the R53 or R56 are more automotive jewelry than anything else. Their performance isn't good. I'd recommend looking at an aftermarket alternative. Try Aaron at Outmotoring. He will know what works. He has an R56 himself.
Congrats on your soon to be new MINI. Welcome to NAM.
100W bulbs mounted in the OEMs make them extremely functional.
Old Jul 8, 2007 | 01:51 PM
  #31
kgdblu's Avatar
kgdblu
yup...and they're called "photon weapons"...
Old Jul 8, 2007 | 02:38 PM
  #32
Crashton's Avatar
Crashton
Certainly higher wattage bulbs would help some. Trouble is the lens controls the way that wattage is used. If the lights aren't very good with the standard wattage bulb they're not going to be a whole lot better with high wattage bulbs. Brighter yes, but better well maybe not so much.
Old Jul 8, 2007 | 04:25 PM
  #33
Mini S Pilot
Thanks everyone for more comments and advice. Thanks for the pics also. I've been scanning through many pics to check out the lights that Mini owners have installed themselves. Many have went to a bigger light in general it seems. Some have even covered the entire front of the car in lights. Top and bottom of the front grill. I haven't seen any light bars on the roof yet, but I'm sure it's out there. Much to consider here. I really don't like that they are wired into the high beams if I keep my order as is. I'd like the option to use them when I want to and how I want to.
Thanks again everyone!!!
Old Jul 8, 2007 | 04:36 PM
  #34
chows4us's Avatar
chows4us
Don't you have vehicle inspections in VA? See http://www.vsp.state.va.us/Safety.shtm.
"INSPECT OTHER LIGHTS FOR: Approved type, proper bulbs, condition of lenses, wiring and switch."
You better check your VA transportation laws because if they are not wired into the highs, you might not pass inspection (if you have to go for inspections).
Old Jul 8, 2007 | 05:03 PM
  #35
Mini S Pilot
Yes I'm aware. Since the lights will sit a touch below the actually headlights they do not apply to this problem with inspectors. Don't ask! I've check and that's what I'm told. You can also cover them and it not apply. Heck it's VA, I'm sure the law is different from inspector to inspector unless you have the law in hand and want to go a few rounds.
Old Jul 8, 2007 | 06:29 PM
  #36
paulgraz's Avatar
paulgraz
I've heard this complaint before, but if you think about how true driving lights work - and when it would be appropriate to use them - having them wired into the high beams makes sense.
But I'd like to hear your side - under what conditions would you want to use them otherwise?
Old Jul 8, 2007 | 06:43 PM
  #37
Mini S Pilot
While driving down back country roads, if I want to use the driving lights without the high beams on also, I'd like that option. I don't like to be restricted in my options. If I want the blinding light of everything on at once that's fine, but I want options.
Old Jul 8, 2007 | 06:48 PM
  #38
Crashton's Avatar
Crashton
If you wire up a set of driving lights independent of the high beams it's only a matter of time until you blind the oncoming traffic with them. Having them tied to the highbeam means one quick click of that switch & all the bright lights are off.
Old Jul 8, 2007 | 06:49 PM
  #39
Eric_Rowland's Avatar
Eric_Rowland
If you go independent, please be courteous of other drivers. It's nice to have blinding lights when you're behind them. If you're in the middle of a turn and you switch off the high beams with the stalk, then have to fumble for the driving lights, the other driver will be blind until you manage to shut them off.
edit: I like my options, too, but when it impacts others, it's best to think twice.
Old Jul 9, 2007 | 05:28 AM
  #40
Mini S Pilot
Man did this go off into left field. Sorry folks, something got lost here somewhere. The roads I'm speaking of I will not be blinding others under no means, if encountering other cars at all. On another note I'm always courteous to others when using my high beams, which I think I've only done twice in the past year to begin with.
It would be just as easy to reach for a self installed toggle as it would be reaching for the high beam cut off. I'm not gadget challenged.
This option would surely not be used as often as some of you have in mind. It wouldn't be an every night switch on, just for those few times a year while on a special driving mission to the middle of no where.
Old Jul 9, 2007 | 05:32 AM
  #41
Xiek's Avatar
Xiek
Well I live in the county, not many street lights, and these really help at night...
and really work when someone flashes me cause they think my Xenon's are my high beams... LOL...
Old Jul 9, 2007 | 05:41 AM
  #42
Mini S Pilot
Thanks for the pic!!!
Those lights look very fitting to your situation.
Old Jul 9, 2007 | 05:04 PM
  #43
chows4us's Avatar
chows4us
... The roads I'm speaking of I will not be blinding others under no means, if encountering other cars at all.
The others are correct. If you have true "driving lights", they will be pencil beams (maybe 5% spread) or "driving lights", maybe a 30% spread. They will reach out WAY beyond your low beams. Having them on the same time as lows is pointless as they will just be acting as highs ... the same as having your highs on.
The point of pencil beams is to go BEYOND your highs, way down the road. The point of normal "driving lights" is to augment your highs with more light.
The bottom line is driving with driving lights on is the SAME as driving with your normal highs on. There is a reason the law is the law in relation to lights ... they augment your highs.
So instead of just flicking your highs off, EVERYTIME a car comes your way, you have to dip the driving lights. If that case ... why not just have your highs on?
That is the reason you got pushback
Old Jul 9, 2007 | 05:40 PM
  #44
Ken Cooper's Avatar
Ken Cooper
I need some input, please. I placed my Mini order Friday, 6/29/07 with the Rally Driving Lights that are installed at the port upon it's arrival. I really thought I wanted these. I ordered the Chili Pepper Red/White Roof/White Bonnet Stripes/w/all the Chrome and thought the ralley lights really set the car off. It's an outrageously high priced option in my book, coming from a 4X4 background and knowing the these type lights are not that highly priced and not hard to install. I know it requires a different grill with cut outs for the lights and a special switch that matches the interior of the car. Heck, the money is not my issue. I've just been viewing so many Minis without them and like that look also. HELP!!!
Does anyone out there have any complaints about the lights? Hopefully they are good quality and hold up to the elements well over time. Any input on this issue would be considered. Has anyone ordered them and not liked them?
I can still change my order, so please give me some advice here.
There were several standard options I wanted but cost became my limiting factor. Had budget allowed me to order the car I really wanted I'd have definitely included the rally lights option. They bring the looks of the MINI into the realm of the true rally car.
Old Jul 9, 2007 | 05:53 PM
  #45
Minut's Avatar
Minut
Couldn't you install a three-position toggle that turns them on in the up position, turns them off in the down position, and links them to the high/low status in the middle?
Old Aug 3, 2007 | 12:32 PM
  #46
Candyman's Avatar
Candyman
Hope this helps
Here's the lite bar on my 07 - as you can see it's not as brite as the HIDs, but it is helpful in fog, etc.
Anyone know if it's legal to use this w/o caps in Pennsylvania?
I would not have bought them, but they were on the car (bought off the dealer's lot).
Attached Thumbnails HELP! Rally Driving Lights - should I or shouldn't I-img_4050.jpg
Old Aug 3, 2007 | 12:41 PM
  #47
Xiek's Avatar
Xiek
I am not sure if mentioned, or if it applies the US or state by state.. But here in Canada, our fog lights go off when high beams are engaged, as you are only allowed to have no more then 4 forward facing lights (not including marker). So when I use my driving lights, in effect it is illegal, as I have at least 6, sometimes 8.
J
Old Aug 3, 2007 | 10:39 PM
  #48
Candyman's Avatar
Candyman
my r56 poimts the fog lights up when the light bar is on and it only works in place of the high beams so it should be legal (I hope) since it's 4 lights at a time.
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
