General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Italian Job the, red cooper S reverse move by Charlize Theron
Old Jul 16, 2006 | 03:12 AM
hexproject's Avatar
hexproject
anyone know how to drive backwards and then spin out going reverse and then go straight like the Italian Job? i think charlize theron was driving the red cooper when she when she did that...
thanks. i want to learn it step by step if anyone can do it.
Thanks.
Old Jul 16, 2006 | 08:54 AM
89AKurt's Avatar
89AKurt
Start with snow...
My only experience is on a parkinglot without cars.
Get to about 4000 rpm in reverse. Flick steering about half a turn to one side (I bias left), then turn more the other direction (right) while pulling on the handbrake and adding gas. As you're rotating, turn back the other direction (left) and floor it, then release the handbrake; let the fwd pull you into the direction desired. Helps to disable the DSC.
Wet smooth pavement, or granular dirt works too. There are many coordinated moves involved where messing up just one part will make you look like a ******* supreamo!
Old Jul 16, 2006 | 08:56 AM
not-so-rednwhitecooper
If you want to do it on dry, make sure the parking lot is sealcoated or you will have issues.
Also, its MUCH easier to do in an automatic.
Old Jul 23, 2006 | 12:29 AM
hexproject's Avatar
hexproject
what? much easier in an automatic? that's weird, i thought manuals are suppose to have better control and stuff
Old Jul 23, 2006 | 04:34 AM
SpiderX's Avatar
SpiderX
Thanks.
Does your Mini know what you are about to do to it......shudder it's not the move...it's the wear and tear from you trying to learn how... go rent a car to practice
BoCRon
Aug 17, 2015 01:21 PM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
