General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Mixing AutoX tires...
Old Apr 19, 2006 | 12:47 PM
ripleybryant's Avatar
ripleybryant
One more question...
When I had America's tire try to mount the V710s(https://www.northamericanmotoring.com/forums/showthread.php?t=66533), they tossed 2 of the old tires(Hoosier A3S03's) because they were showing cord on the outside edge.
So.. We have an event this Sunday and I was planning to run the 2 good Hoosiers on the front and the runflats on the rear. Unfortunately, in the time we have between now and Sunday, I don't have time to get another set of tires.
So.. Any reason not to run this setup this weekend? I figure the runflats'll allow the rear to rotate easier if nothing else.
If it helps.. Our venue is not very big, so our courses tend to be fairly tight, mostly 1st gear and a little bit of 2nd gear, so there won't be any fast sweepers or anything.
Thanks!
Old Apr 19, 2006 | 01:03 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Should be fine been running a mix set up simular to that for a while now.. help the car rotate the way i want it.
Old May 6, 2006 | 04:19 PM
NoWin's Avatar
NoWin
Ditto....if the speeds are relatively low (1-2 gear), it should be OK.
We have one site we visit in New England that requires a slow and tight course by design, and I often run the Kumho Victracers up front, and leave my Azeni's on back.
Eddie
New England SCCA Solo2 Novice Chief
IQRaceworks
53
Jun 28, 2024 07:29 AM
VanisleRyan
Sep 30, 2015 08:35 PM
XsV
24
Sep 30, 2015 03:17 PM
R53UndaPSI
Sep 21, 2015 09:42 AM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
