General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Aerodynamics for a MINI
Old Oct 16, 2019 | 10:09 AM
squawSkiBum's Avatar
squawSkiBum
Moderator
I have been reading a lot about aero for cars lately and the tradeoffs for drag and downforce. Given that I'm an engineer and like to geek out on things, here is a link I found really interesting: https://occamsracers.com/miata-aero-test-at-wgi/
One thing that I found really interesting is that a rear diffuser can both reduce drag and increase downforce. There are various wings and splitters available for MINIs but very little real data on how well they work, Sneed seems to be the only vendor that has any measured data published. So I thought I'd start a thread to see what other people are doing and hopefully share real data.
Last weekend I finally completed my long desired upgrade to the GP2 diffuser - buying the diffuser kit, buying the JCW rear bumper cover and getting it painted, figuring out and buying all the bits and pieces for the lights and trim. I haven't added up what it all cost because it was a LOT, and I don't want to know. Why do it? Honestly because it looks so cool, and it should be functional too - less drag and more downforce, right? I don't have a way to measure downforce (yet) but coincidentally I was doing some hyper-miling experiments so I have a really good understanding of my long term average MPG and also what is possible by changing my driving behavior. (About a 25% increase in MPG over my daily commute, and a 1000% increase in boredom!) Any reduction in drag should show up as improved MPG. Stay tuned.
Anyone have anything to share?
Old Oct 16, 2019 | 03:42 PM
sub3622's Avatar
sub3622
Did you also install the under body panels that go from the front of the car to the rear diffuser? that is, the panels that connect to the rear diffuser.
Reason i am asking is because those are very important.
Old Oct 16, 2019 | 05:35 PM
squawSkiBum
Moderator
I have had the front panel under the engine for a long time. I haven't bought the panels that go between the front and the diffuser yet. Stuff I have read says the diffuser by itself is a big improvement, and a flat floor makes it work better.
I have some ideas about adding some DIY panels from the forward end of the diffuser channels to the body, I think that will get me about 80% of what the full length panels would do.
Old Oct 17, 2019 | 02:35 PM
sub3622's Avatar
sub3622
Exactly, those under panels make the air go smoother. I ran into this issue a while ago when i bought just the diffuser and what happened is that at high speeds the air accumulated between the diffuser and the chassis causing damage to the diffuser. Clips were broken and the screws were somehow released from the high vibration that caused the air.
Old Oct 17, 2019 | 07:23 PM
squawSkiBum
Moderator
Yah, I looked at it and had the same concern about that space between the front of the diffuser tunnels and the body being an air scoop. My car has a plastic tab that is maybe 6" wide by 1" tall that sticks down from the body on either side ahead of the rear suspension, it appears to be an air deflector to maybe help prevent the whole area in front of the rear bumper from being a big parachute. My idea is to use the studs those tabs mount to as a front mounting point for some plates that will connect to the front edge of the diffuser tunnels, the way the full length panels do. I need to get the car back up on the ramps and crawl under it to do some CAD then cut the panels. I'll either get some thin aluminum sheet or maybe a sheet of alumalite to build them.
Old Oct 17, 2019 | 08:40 PM
Fly'n Brick's Avatar
Fly'n Brick
Please forgive the minor hijack, your thread title caught my attention in respect to my chosen screen name.
Old Oct 17, 2019 | 09:37 PM
squawSkiBum
Moderator
It does seem kind of oxymoronic to mention MINIs and aero in the same sentence. But I'm sure there are things that can be done to improve the aero performance even for a brick. I'm looking for ways to measure and quantify the impact, good or bad, of changes, and not just sticking something on the car because it looks cool. (Though I have to admit that the GP2 diffuser does look really cool and that's part of why I installed it.)
So far the difference in MPG after installing the diffuser is so big that I don't believe it, I'm going to wait for a few hundred miles more before making any claims. Meanwhile since I don't have a wind tunnel I'm thinking about what I could do with some bits of yarn and the GoPro. And there's some inexpensive digital manometers available on Amazon that could be fun to play with.
Old Oct 18, 2019 | 02:52 PM
sub3622's Avatar
sub3622
Just try not to go too fast in the mean time because when that happened to me I was going no more than 100 MPH, actually i would say 80 to 90 MPH.
Old Oct 18, 2019 | 02:53 PM
sub3622's Avatar
sub3622
Old Oct 19, 2019 | 10:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The GP2 aero parts are beneficial, even if the car is a brick. I added the GP2 front skid tray to my Clubman, and noticed a few point is additional mpgs. I wish there was a suitable option for rear diffuser that would work on the Clubman.
Old Oct 22, 2019 | 08:21 PM
squawSkiBum
Moderator
Here's a pic of the tab I mentioned in post #5 - it is the greenish looking thing (funny effect of the flash) just ahead of the gas tank. There's another one to the right that is further back, just ahead of the rear wheel.
A little bit of CAD (Cardboard Aided Design) and I have a template for a panel that will use the mounting studs for the tab and connect to the front end of the diffuser tunnel. Today I picked up a big piece of leftover 3mm ACP from a local sign shop for $20 to cut the panels out of - pics when it's done.
Old Oct 23, 2019 | 11:10 AM
sub3622's Avatar
sub3622
Cant wait to see the results.
Old Oct 30, 2019 | 07:09 AM
Serafin's Avatar
Serafin
Any update of this?
Old Oct 30, 2019 | 09:35 AM
squawSkiBum
Moderator
Thanks to PG&E shutting off the power to a good chunk of Northern California, I didn't get any garage time in last weekend. Finally got power back on after 3 days of flashlights and takeout. At least we still had hot water. I hope to cut and install a first try this weekend.
After about 500 miles with the aero bumper and diffuser, my long term average MPG has gone from 31.1 to 33.6 - an 8% increase! I find that astounding - why didn't every MINI come this way? If I change my driving habits slightly I can get to 34 easily, if I hyper-mile I can get to 40+.
Old Nov 9, 2019 | 09:36 PM
squawSkiBum
Moderator
Left side is done, here's a couple of quick pictures. It is hard to see in the first picture, there is a S bend formed into the panel on the left side so it flows nicely over the gas tank to the attachment point on the underside of the car. The second picture shows the panel mounted on the car, the step is visible at the far end. The ACP will bend but only over a large radius otherwise the aluminum on the outside of the panel will tear. It took some experimenting with scrap pieces to figure out a jig that would create a smooth S bend across the width of the panel without tearing the outer skin. The material is really easy to cut, I used my radial arm saw for the long straight stuff, the jigsaw for the smaller stuff, and the dremel to round off the corners.
Now I need to build the other side.
Old Nov 10, 2019 | 08:24 AM
Serafin's Avatar
Serafin
This is awesome. Did you make that skid plates too?
im ready to put in my order.
i just installed the Leap Diffuser and want some kind of under Panek to connect them. Also waiting for the rear bumper grill. Functional one lol
Old Nov 10, 2019 | 08:43 PM
squawSkiBum
Moderator
the aluminum part in the foreground of the pic is the forward edge of the GP2 diffuser tunnel, the white panel forward of that is the part I made.
squawSkiBum
Moderator
I came up with an idea for a better way to quantify any change in drag. One way is to do a "coast down test" where you measure the time to coast from say 80 mph down to 50. But doing that on public roads would have a good chance of getting noticed. Another way is to monitor the MAF reading while holding a constant speed using cruise control and average the readings over as long a period as possible and driving both directions. Measuring the air going into the engine should directly correlate to the engine load required to hold a constant speed. There's a road near me that's perfect for this - long, flat, straight, and a 50mph speed limit. (A couple of times over the years, late at night I have come across drag racers lining up on that stretch.) So I'll try that, comparing data from before and after installing the panels.
Old Dec 28, 2019 | 09:15 PM
squawSkiBum
Moderator
I finally got some garage time today and finished up the panel for the other side. Here's a pic of both of them in place (need to install the screws to connect to the diffuser tunnels.) Now I need to find some drive time to do the data logging to see if I can measure a difference between panels / no panels. This won't be as good as the much longer underbody panels but my total cash outlay is $20 so it is good cheap fun experimenting.
Also interesting is that my mileage has dropped recently, it is still better than the long term average before I installed the diffuser but not the big gains I saw earlier. There are two possibilities - one is CA switches to a different gas blend in winter which will affect mileage, the other is I have the stock suspension swapped in while I have the Ohlins out for rebuild so the car is sitting about an inch higher, therefore more air under the car. Maybe it is some of both. I'm planning to do direct comparisons with/without the panels, and before/after swapping the Ohlins back in - same day, same tank of gas.
Old Dec 30, 2019 | 04:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Well done, sir! Your creativity might inspire me to build some for my Clubman
Old Feb 7, 2020 | 04:24 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
In general it's hard to change the overall front aero shape of the MINI - front bumper, bonnet, windshield, hoodline.
Front lower lip/ aero splitter, rear diffuser and rear wing are possibles. Aero side mirrors and lower suspension with possible mild rake could help. Canards are not that useful
Old Apr 4, 2020 | 02:39 PM
squawSkiBum
Moderator
With the coronavirus restrictions I'm supposed to be staying home, I have been working from home the last two weeks and hardly going out at all. Yesterday I broke quarantine and finally got out to do a back to back comparison without the panels and then with to see if I could measure any difference. I used Torque to record the MAF sensor output (g/sec) with the cruise control set at 60mph on a long straight stretch of 2 lane road. I logged both directions since there are some slight elevation changes, total distance for each run was about 2.5 miles. Exported the logs to a spreadsheet and averaged the MAF readings for the time at 60mph... drumroll... adding the panels reduced the average MAF reading by 1.5%.
It's fair to ask - is that meaningful, or experimental error? Was I going fast enough to see a difference? Is one 2.5 mile trial for each case enough to get good data? I expect the differences to be small, but measurable with careful procedure, so I am optimistic that there really is some improvement. I'm going to see if my long term average mileage improves with the panels on. Unfortunately it is going to take a while to get any meaningful data since all of CA is staying home.
Old Apr 11, 2020 | 12:31 AM
JannerSy's Avatar
JannerSy
I've got my front splitter all the way back to the power steering fan. It then links into the R56 underside panels and then the GP2 diffuser.
Old Apr 11, 2020 | 12:50 AM
JannerSy's Avatar
JannerSy
Old Apr 11, 2020 | 06:12 AM
Serafin's Avatar
Serafin
who makes those splitters? Did it come with the V mount that connects to the crash bar?
