General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Schroth Quick Fit for R56
Old Aug 13, 2012 | 06:36 PM
  #26
Eddie07S's Avatar
Eddie07S
Originally Posted by WayMotorWorks
FYI we've been shipping the R55 R56 R57 Schroth harnesses for about a month now. still have them in stock too.
Old Feb 14, 2013 | 09:31 AM
  #27
Mindspin311's Avatar
Mindspin311
So, to confirm, since these harnesses have the yellow on them, they will fit the R56. Even tho the tag states R50?
Old Feb 15, 2013 | 01:47 PM
  #28
Eddie07S's Avatar
Eddie07S
I will say "yes" it should fit. My guess is that with the ones with the "yellow Schroth" label the tag has more to do with liability and certification than "fit". The one that I have that says "R50/R53", like the one you are showing, is identical to the one I bought that says "R56".
If you want to check it, you only need to snap it into the car's part of the buckle that it uses before you do the whole installation.
Old Mar 8, 2013 | 04:21 PM
  #29
Mindspin311
Is there a specific angle the rear seat tethers need to be at. It sure is a pain getting them to stay where you want as you torque them into place. I got mine close, but not perfect.
Old Mar 8, 2013 | 04:52 PM
  #30
TerminalVelocity's Avatar
TerminalVelocity
Originally Posted by Eddie07S
Sorry, too amazed that they finally complete the project to read closely enough to notice the difference
Link for the base model:
http://www.hmsmotorsport.com/store/s...quick-fit-mini
Does anyone know if these will work on the R58 and R59?
Old Mar 8, 2013 | 05:01 PM
  #31
Eddie07S's Avatar
Eddie07S
I would "guess" no. They need the rear seat safety belt attachment point to work.
Old Mar 8, 2013 | 05:20 PM
  #32
Eddie07S's Avatar
Eddie07S
Not sure what you mean by "...stay where you want them..." They should go in between the posts of the headrest and down over your shoulders. Tighten the lap belt first so you can't breath (just kidding, but really tight) and then each of the shoulder straps. The length of the strap in the back should be such that you have adjustment room on the shoulder straps. I have never had a problem with them staying put.
Old Mar 8, 2013 | 05:24 PM
  #33
Eddie07S's Avatar
Eddie07S
Ooops, did I miss read your concern? Are you talking about the metal piece that goes on the safety belt frame bolt????
If that is it, then mine is not "perfect" either. I would think that it should be somewhat in line with the belt as it heads to the seat. That is what I "aimed" for when I did my installation.
Old Mar 8, 2013 | 06:27 PM
  #34
Mindspin311
Yea, poor description on my part. The rear seat pigtails with the metal bracket.
I did my best to line them up, but yea, not perfect.
As long as I can get my back seat in tomorrow, ran out of daylight today.
Old Mar 9, 2013 | 12:46 AM
  #35
Agbullet25's Avatar
Agbullet25
I'm curious to know if this harness has enough slack to be used in conjunction with the Monkeybar from Kappasphere and still connect to the rear attachment points.
DixonL2
Apr 13, 2021 08:05 AM
W0TM8
Dec 19, 2019 07:50 AM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
xpunisherx
Aug 10, 2015 10:50 PM
