F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
How to keep the green light on around the information center.
Old 08-23-2017, 04:06 PM
pinover's Avatar
pinover
pinover is offline
When I put the car in green mode it shows green in the speedometer and "sometimes" the green led shows up around the center cluster. At other times, without touching any dials or doing anything different the led around the center dial shows the tach and nothing I can do changes it. I can move the dial to change to green and although it shows "green" in the speedometer the green led does not. I have a 2015 4 door hardtop that I just purchased.
Old 09-02-2017, 11:07 AM
Lucila's Avatar
Lucila
Lucila is offline
I believe you can change it in the display settings to match the color of your mood lighting. There's a toggle up on the roof that will change the interior mood lights to different colors. The ring will then change to the set color.
Old 09-02-2017, 12:03 PM
hammerhands's Avatar
hammerhands
hammerhands is offline
There are settings under Center Instrument.
1. Menu button.
2. "Settings"
3. "Center Instrument"
4. "Basic display" or "Event display"
5. Select desired setting.
You can choose if it shows the tachometer, temperature changes, connection with the phone, etc...
MrMicL
12-22-2023 04:39 PM
ERIK06MCS
08-24-2017 05:50 PM
sumoka
07-21-2017 10:26 PM
Tanner Stinson
06-24-2017 12:40 PM
Chuck93GT
06-15-2017 06:23 AM
Quick Reply: How to keep the green light on around the information center.
