Cylinder Head Cover Replacement
Old Feb 15, 2016 | 08:59 AM
RS11's Avatar
RS11
Recently, on a cold start my 2011 Countryman (65,000 miles) has been making a loud screeching sound. By the time I drive out of my neighborhood (about 1/2 mile) the sound stops. The car otherwise operates fine.
I took the car to the dealer to be checked out. They could not replicate the sound. When I drive out of the dealer service bay, the sound immediately starts. I drive back around and into the service bay. The car sits there in the service bay and "performs" (that is, makes the noise very loudly) for the service techs. The mechanic literally runs down to check out the car. He says he knows the sound immediately. He pulls up the dipstick about an inch and the sound stops. Puts it back in and the sound starts again. He then fights to pull off the oil cap. It's under vacuum pressure and is hard to remove. When he gets it off, the sound stops again.
Diagnosis. I believe he said that one of the oil separator valves (?? not sure about this) was bad. The fix requires replacement of the cylinder head cover. That's a $500 part with an extra $300 for the work.
Any known problems with these? I searched but didn't find much. This seems like a part that should not fail at 65,000 miles.
Old Mar 2, 2016 | 06:57 PM
PoopCoop's Avatar
PoopCoop
sometimes part just fail man. they diagnosed it, so have it fixed or just leave your pcv system clogged... eventually causing oil to leak out of every part of your engine and acids to build up and destroy your engine from the inside out.
Old Mar 3, 2016 | 04:12 AM
RS11's Avatar
RS11
Thanks man. I guess I should reevaluate my plan to let my engine fail from the inside out.
Old Mar 3, 2016 | 07:38 AM
Yes, the PCV valve sets in the cover itself, most have issue on the N14 engine ( pre countryman ) You have a N18 or N16, its happens just more rare
Countryman or Countryman S ?
If you are mechanical you can replace it yourself.
Old Mar 3, 2016 | 08:34 AM
RS11's Avatar
RS11
Countryman S.
And, I wish I was mechanical but I'm not.
Old Mar 3, 2016 | 08:50 AM
ok, well if you can find someone or tackle this on your own. This works also for all Countryman and Paceman Models with that cover, also ALL the MINI Coopers with the N18 engine that uses that same cover.
11127646552
This is the main cover , comes with seals, new oil cap and main install hardware, bolts and nuts .
https://www.ecstuning.com/Search/SiteSearch/11127646552/
Thats the engine bay , you will need to move all the items away and that ront cover pops up and out on the front portsion.
Use this as a guide:
https://www.northamericanmotoring.co...n-pcv-fix.html
And here is the diagram:
http://www.realoem.com/bmw/enUS/show...71#11127646552
Intake side: Just #19 needs undone.
http://www.realoem.com/bmw/enUS/show...diagId=13_1212
Old Mar 3, 2016 | 09:58 AM
RS11's Avatar
RS11
That's incredibly helpful. Thanks!
Old Mar 11, 2016 | 08:44 AM
You are welcome.
Old Feb 9, 2018 | 05:45 AM
Just an update, these are back in stock now.
Alen Svigelj
Oct 17, 2023 08:15 AM
miniuy
Dec 9, 2019 07:13 AM
jacky_mini
Apr 25, 2015 01:36 PM
boognish
May 30, 2014 03:04 PM
Scrumpy_Jack
Jan 2, 2012 01:20 PM
