R55 R55 oil pump replacement
Old Dec 27, 2019 | 03:50 PM
furnitureman9's Avatar
furnitureman9
2009 Clubman JCW R55
Anybody have any experience changing an oil pump, chain and sprocket. What all parts and gaskets do I need? What are the steps involved.
Thanks!
Old Dec 27, 2019 | 07:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Keep in mind you will need to lock the cams and set the timing as you will need to remove the bottom crank bolt to remove the crank sprocket and chain for the oil pump.
This is why we do the chain for the oil pump when we do the timing chain.
https://www.waymotorworks.com/febi-o...9-r60-r61.html
Otherwise you remove the oil pan and pull the pump from there.
https://www.waymotorworks.com/oil-pu...-cooper-s.html
duke013
Sep 17, 2019 05:19 AM
wascobi
Jul 12, 2019 08:41 AM
plasticknives
May 27, 2016 05:22 AM
shbiv
May 23, 2016 12:48 PM
satkinson2002
R55 :: Clubman Talk (2008+)
Feb 13, 2015 06:29 AM
