Digital Therm the Turbo.
Old Aug 1, 2011 | 07:52 PM
Jolio's Avatar
Jolio
After I got home, I busted out the digital Thermometer to see the how hot the turbo got.
I didn't over work the engine getting home, just got home as usual.
This was the one with two rivits.
This was the Turbo heat shield itself.
Old Aug 1, 2011 | 09:43 PM
Spice Orange JCW's Avatar
Spice Orange JCW
On my diesel truck I have a pyrometer in the exhaust just before the turbo. At cruising speed I see exhaust temps anywhere from 600 to 900 depending on the terrain. I can easily get the temps up to 1100 when I floor it. I know with that vehicle you do not want temps to stay over 1250 or you could melt the fins. Now diesel has more BTUs than gas, but I would think that those temps are well within the specs of a gas engine.
Old Aug 6, 2011 | 10:39 AM
blackbart's Avatar
blackbart
Many have posted pics of our turbos glowing a dull orange after a hard run. That relates to over 1100 degrees but the alloys used in the turbo wheel and housing are fine at those temps. The "rivet" you measured is part of a heat shield designed to isolate the "oil in" side of the turbo. This should naturally be cooler than the turbo housing two inches to the left. Give it a run and measure the curved surface under the shield!
Old Aug 6, 2011 | 11:59 AM
toyopet's Avatar
toyopet
coking
Talking about high temps, how many of you are driving moderately without going into boost for the last 5 or so minutes before shutting off the engine?
I know with the newer synthetic oils on the market, coking is not going to happen too soon. Preventative measures never hurt though.
Old Aug 6, 2011 | 01:30 PM
Spice Orange JCW
There is no need like other cars to cool down the turbo. The turbo is cooled after shutdown by water being pumped through it.
Old Aug 7, 2011 | 08:50 AM
quality_sound's Avatar
quality_sound
It's not that the turbo is staying hot it's that it's staying hot and the oil isn't circulating anymore so any oil still in the hot turbo will coke. Yes, the water still circulates to cool the turbo but that does nothing for coking.
Oct 19, 2015 08:07 PM
pglgp1292
Oct 5, 2015 06:47 PM
Sep 29, 2015 03:36 PM
stellaherself
Sep 16, 2015 06:56 AM
GregoryK
Sep 10, 2015 10:54 AM
