Indicator and Warning lamps
Old Mar 27, 2011 | 11:56 AM
worm's Avatar
worm
When i start my engine this morning there is a warning sign,heard some noise on the engine,i looked at the manual the indicator says lights up in yellow: full engine power no longer available.Anybody experience it on their JCW?
Old Apr 7, 2011 | 06:51 PM
worm's Avatar
worm
i think i am the only one who experience this problem,and i feel this is the last mini that i will owned not worth it for 42k
Old Apr 8, 2011 | 06:13 AM
timfitz63's Avatar
timfitz63
Originally Posted by worm
i think i am the only one who experience this problem...
Actually, you're not the only one who's seen this trouble light, but any number of problems could trigger it.
If you're looking for help in diagnosing your particular problem, you need to provide more details than you did in your original post and/or make use of the forum's search utility to research the threads that mention the trouble light you're getting to see if there's already an existing thread discussing the symptoms you're experiencing.
Regardless, when you first saw this trouble light, you probably should have scheduled it in for service. Since you're posting this in the factory JCW forum, I presume that's the vehicle you have, in which case it's likely to still be under warranty, and ultimately any diagnosis/corrective action should be performed by the dealer at no cost to you.
Old Apr 8, 2011 | 07:01 PM
worm's Avatar
worm
Yeah i scheduled it last week, when i called i told the dealer about the indicator lamp and he told me it is only a software problem and it can be fixed,i brought it last tuesday diagnosis is there is an air leak on engine,but on thursday same problem appeard in the indicator lamp the max speed is 0nly 20mph,no power and keep on stopping.Dealer called early morning today and leave a message that there is an issue on high pressure fuel pump that need to be replaced.Thanks timfitz63 for your reply really appreciated it.
Old Apr 9, 2011 | 05:28 AM
timfitz63's Avatar
timfitz63
No worries. HPFP is a common problem with the turbocharged models. Hope that it finally gets sorted out!
Alpha Motoring
Nov 10, 2015 07:08 AM
vulkandino
Oct 31, 2015 08:29 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
