Max tire width on the Challenge Spoke?
What is the wheel width and offset? Also depends on what tire aspect ratio you want to use. I suspect the width is 7", if so the maximum recommended width (per Tire Rack) is 215 for a 35 series and 225 for a 40 series. It is recommended that a 225/35 use a 7.5" wheel. The wheel offset will help determine if there will be inside or outside rubbing issues.
Difference should be minimal:
215 x 40% = 86
225 x 35% = 78.75
(difference of 7.25 mm sidewall height)
but
215 x 35% = 75.25
225 x 40% = 90
(difference of 14.75 mm in sidewall height)
Kimolaoha
12-05-2020 09:32 PM
hexproject
09-07-2015 08:23 PM
