F57 :: Convertible Talk (2016+) Cooper and Cooper S convertible (F57) discussions.
F57 Dash cam install
Old Sep 1, 2025 | 05:21 PM
gargoyle7642's Avatar
gargoyle7642
Dash cam install
I thought I'd share photos of my dash cam install. I was looking for a unique way to mount the rear camera so you could see with the top up and the top down. The only thing is that I will have to remember to unplug the cord before I put the rear seat down. Fortunately I don't do that very often. Let me know what you guys think.
With the top up!
With the top up!
With the top up!
With the top up!
Old Sep 6, 2025 | 05:34 AM
Cableaddict's Avatar
Cableaddict
An interesting idea, and the view is better than I expected.
I have yet to install such a system, simply because I can't find anything of high enough quality. (Sunlight readable, and hopefully with an auto-brightness sensor.)
But there are a few things that bug me about this install:
1: It's probably better to have it in the center of the car, for a more accurate sense of L-R, though I suppose the side mirrors help with that so maybe a non-issue.
2: I looks a bit goofy. (Would be less goofy in the center.)
3: As you say, watch out for the wiring.
4: I have read many reports that most (all?) of these LCD's suffer from glare. From the sun but mostly from headlights at night. You can add film to help, but then that takes away some contrast & crispness. Because of this, I'm just about to have my rear window tinted very dark. (Planning on mounting a camera in the back.)
So... this would not work for such a setup.
I love how high it is, though. I was going to mount my camera on the rear license plate, as most people do, but your pics have me re-thinking this.
Maybe there's a way to use a similar "mounting stick" on the back, so the camera is just at the top of the convertible top when it's down.
That's gonna be tricky to make it look right and not cause much damage to the car, but it WOULD be ideal.
More likely I'll try to attach a mount to the beltline. - Still significantly higher than the plate, and if it doesn't work, the beltline can easily be replaced, covering the holes.
Hmmm... Maybe your way is better, only moved to the center.
That would mean getting a lighter tint on the window, of course, so maybe having to deal with more glare on the LCD.
- But it would look much better than the external kludge..
Old Sep 7, 2025 | 12:03 PM
gargoyle7642
I looked at other headrest mounts (see attached photo) to center it, but they didn't adjust vertically, only horizontally. You also have to keep it close to the headrest so that the top doesn't hit it while putting it up & down.
It really isn't that far off center and with the camera's 140° field of view, the rear view completely records everything.
It does look a little goofy, but I'd rather have a rear camera than not have one and look better. (My daughter was recently hit from the rear and has the same camera system)
Info from manufacturer:
  • SONY STARVIS 2 SENSOR/SUPER NIGHT VISION – Equipped with a Sony IMX675 STARVIS 2 Image Sensor for the front camera, this dash cam delivers exceptional image quality with vivid colors and sharp details, even in challenging lighting conditions. Additionally, the front camera's F1.5 aperture and the rear camera's F1.8 aperture allow more light to enter the lens, resulting in brighter and clearer recordings, particularly in low-light environments.
You could also tint the rear glass as well. I will try and get some night pics as well.
Old Sep 12, 2025 | 12:24 PM
Bongo Bob's Avatar
Bongo Bob
Rear Dash Cam Wiring
How did you route your cable for the rear camera?
Old Sep 13, 2025 | 08:07 AM
gargoyle7642
Wire routing
From camera to rain sensor housing, under windshield top trim to passenger's side A-pillar, under passenger door sill, to rear passenger's side trim, then up to cross section behind rear seats, then out one of the bolt covers. It did take a while to figure out the routing and then how to get some of the trim pieces off! I finally gave up trying to remove the side trim by the rear seat and used metal wire to fish the power cord behind it.
Old Sep 13, 2025 | 08:13 AM
gargoyle7642
Top down photos
Old Sep 13, 2025 | 09:10 AM
Bongo Bob's Avatar
Bongo Bob
Thanks for the info..... think I've got it figured out....
Old Sep 18, 2025 | 11:45 AM
Cableaddict
Thx for the pics, Gargoyl !
That doesn't look bad at all. (though I'd love to see a night time pic as well, with car headlights shining forward.)
How does the depth perception seem to you?
I've found a couple of decent-quality rear cameras at 120 degrees, and that seems to be the lower limit right now fort available gear.
oe542bob
Nov 15, 2023 05:59 AM
carid
Dec 29, 2020 06:40 AM
diablito
R57 :: Cabrio Talk (2009+)
Nov 23, 2011 07:50 AM
TWISTER
Mar 18, 2009 05:27 PM
TWISTER
May 31, 2005 03:46 PM
