F57 :: Convertible Talk (2016+) Cooper and Cooper S convertible (F57) discussions.
F57 Mileage
Old Sep 2, 2019 | 10:19 AM
Moondog1957's Avatar
Moondog1957
Mileage
I need some help. I have a 2019 F57 (base model). I had Bimmertech code my car with the Sirius/XM (no issues), then I added the digital speedometer and door lock. It appears now with the digital speedometer that I can’t see the mileage anymore on the car. Has anyone had this issue? Can you tell me how to fix this if you did? Any help is appreciated. Thanks...
Old Sep 2, 2019 | 10:28 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Push button on left side stalk to cycle through the display. At least that is how it works/worked on our other F series cars.
Old Sep 2, 2019 | 10:30 AM
Moondog1957
That doesn’t appear to work. I tried the menu also on the info system, can’t seem to find a pathway to it. I am wondering if I need to go back to Bimmertech to see if the coding process messed something up?
Old Sep 2, 2019 | 11:02 AM
Minnie.the.Moocher
I'd email Bimmertech, he is pretty responsive and might have a simple answer. I do note that sometimes when I've coded things it turns other things off. For example the lights flashing on car unlock always toggles off and I have to reset in the options menu. It might be buried in those menus.
Old Sep 2, 2019 | 11:07 AM
Moondog1957
Thanks Minnie...I will email them. I know it is something simple, and I probably just missed it. Thanks
Old Sep 12, 2019 | 06:43 AM
Walt's Avatar
Walt
At least for me, when I cycle thru the display choices, and I get to the speedometer one, it will show the speed on the top right, and the mileage (odometer) on the bottom right, but only for a few seconds. After those few seconds, the mileage (odometer) will disappear, and the speed (speedometer) will double in size, taking over both the top right and the bottom right.
If you want to see the mileage (odometer), you need to cycle thru the display choices again.
Old Sep 18, 2019 | 10:04 AM
NBCGLX's Avatar
NBCGLX
Mind elaborating on what exactly was coded for the digital speedometer? As far as I know, that's a standard feature and is one of the many options you can scroll through with the BC button on the end of the turn signal stalk.
mlg321
R60/R61 Stock Problems/Issues
Jan 23, 2017 12:39 PM
Hedjuk
36
Mar 28, 2011 09:23 PM
RaT48
Electrical
Aug 1, 2007 09:35 PM
sunnyhorse
Jan 2, 2006 07:49 PM
CC
Jun 7, 2005 11:46 AM
