F55/F56 Caliper Replacement Question
Old Dec 15, 2025 | 10:06 AM
2door15's Avatar
2door15
Hello All,
I have to replace my rear left caliper and wanted to verify if I should have the car running when I pump the brakes to fill the new caliper as well as when I bleed the air.
I will be doing the procedure with an assistant. Thanks in advance.
Old Dec 20, 2025 | 04:58 PM
UnderWaterAce's Avatar
UnderWaterAce
Originally Posted by 2door15
Hello All,
I would recommend using a pressure bleeder at 15psi. I could never get the air out of my replacement caliper doing the normal brake pedal method, car on or off, until I got a pressure bleeder.
Old Dec 21, 2025 | 04:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I love my pressure bleeder.
Here are my tips for replacing a caliper…
First, before removing the caliper, depress the brake pedal and lock it in place. This might sound counterintuitive, but it sets the master cylinder piston in place to prevent fluid from draining out when you disconnect the caliper hose. Then, when the work has been completed, and the caliper has been replaced, unblock the pedal and proceed with the pressure bleed on the replacement.
When bleeding the air out of the replaced caliper, crack the bleeder screw very slowly. You want whatever air in it to compress from the pressure bleeder. You want the fluid coming in to displace the air as slowly as possible. This makes sure you have no entrained air left in there.
Like most automotive maintenance tasks, it can be intimidating at first, but take your time and it will turn out well.
Old Dec 21, 2025 | 09:04 AM
2door15's Avatar
2door15
Most appreciated!
Shotgun_banjo
Mar 26, 2022 02:05 PM
Black Sharpie
Jan 20, 2015 04:36 PM
DaKineMINI
Tires, Wheels, & Brakes
Jul 25, 2005 02:57 PM
