F55/F56 rear fender wheel arch light
Old Jan 19, 2025 | 05:43 PM
froggio's Avatar
froggio
Hello Mini community,
I own a 2019 Mini F56 (base hatchback, 2 doors).
The rear right side marker in the fender (wheel arch) is not working anymore.
Is this a enclosed LED unit to be entirely replaced or is it a regular bulb to swap?
Thanks!
Old Jan 20, 2025 | 09:40 AM
Hello,
It connects with double sided tape from the factory. Its Led on the F56+ MINIs.
Rear left: https://www.ecstuning.com/Search/Sit...h/63217297547/
Rear right: https://www.ecstuning.com/Search/Sit...h/63217297548/
You can see the white plastic that goes around the outside that gets pealed off to stick.
Old Jan 20, 2025 | 02:34 PM
froggio's Avatar
froggio
Thank you so much. I did some research and was wondering why the perimeter was white, unlike the current light on my Mini
Old Jan 21, 2025 | 06:00 AM
Yep, first time MINI made them like that, before they were all screw on.
You just have to clean the surface of the old location before you stick. Alcohol wipes work.
https://www.ecstuning.com/b-bremmen-.../54845t29~brp/
Old Jan 21, 2025 | 03:16 PM
cjv2's Avatar
cjv2
A tip: well, two tips.
(1) The double-sided tape can stick to either the lamp assembly *or* the fender liner when you remove the old lamp assembly to replace it. You'll want to make sure that you get all that double-sided tape off of the fender liner for sure. A utility knife with a good sharp blade, thoughtfully applied, will do the job. If you don't get it off of there, you'll find that the new lamp doesn't sit flush and may not even adhere uniformly in general. Very important for reassembly: don't rush letting the tape cure in place. Or you may end up annoyed later.
(2) If the replacement lamps you get don't come with double-sided tape already affixed, the product to use is 3M's VHB 5925. As a result of my experience with item (1) and needing to replace my wheel arch liners entirely, I ended up having to remove the lamps and reinstall them. This 3M tape was a lifesaver. Super-thin, matches original spec in terms of its depth measurement. Link to product on Amazon:
Amazon Amazon
Old Feb 26, 2025 | 09:33 AM
froggio's Avatar
froggio
Thank you so much for the info, it will make life easier for sure. Still waiting for replacement part a month later...
Jas31483
Jul 28, 2025 01:52 PM
r53beast
18
Sep 25, 2014 01:01 PM
Quadrivium10
Electrical
May 26, 2013 07:31 PM
Miniriffic
May 26, 2013 07:30 PM
nfo
Apr 1, 2003 07:57 PM
