F55/F56 How do you remove this from the side turn signal?
Old Sep 6, 2022 | 09:38 AM
srpena's Avatar
srpena
I would like to know if any of you removed this piece that surrounds the side indicator of my Mini. It's horrifying:
Is it glued or does it have a hole?
Thank you very much
Old Sep 6, 2022 | 10:44 AM
RichsMINI's Avatar
RichsMINI
@srpena, the scuttle surrounds are installed using Betalink, a glue BMW/MINI uses.
Some dealerships installed them using 3M automotive double sided tape instead of Betalink.
This picture is from the official instructions and shows where the glue is applied.
I hope this helps,
Rich
Old Sep 6, 2022 | 01:49 PM
TVPostSound's Avatar
TVPostSound
Betalink is an adhesive to glue spoilers on BMWs
As mentioned, it MIGHT have been dealer installed with 3M which comes off way easier.
You can try to soften with a heat gun and hope it comes off without damaging the paint.
I would leave it alone.
Old Sep 7, 2022 | 08:07 AM
srpena's Avatar
srpena
Thank you so much for the answers.
Old Sep 7, 2022 | 02:34 PM
David9962000's Avatar
David9962000
A blow dryer is your friend.
Old Sep 21, 2022 | 09:22 AM
mcbacon89's Avatar
mcbacon89
Good question because I'm curious about this, too. I'd ideally like to take the checkerboard style scuttle surrounds off mine since they're starting to yellow after seven years in Southern Sun.
If I can't get the glue off to go to paint again, I'll definitely be going with the style you have. I suppose alternately I could have a replacement panel put on but that's a lot of money for not a lot of gain.
David MacNeill
Feb 3, 2022 11:31 AM
ChubbyChecker
May 1, 2014 07:40 AM
CaptainCradicles
Nov 10, 2009 09:50 AM
