R56 F56 Rear Calipers
Old May 26, 2022 | 07:41 PM
Chappy's Avatar
Chappy
F56 Rear Calipers
Hey guys, need some help please.
So our daughter drives a 2018 Mini/R56 with about 29,000 miles on it currently. She purchased it last year from the original owner, clean carfax, warranty and service history, etc. etc.
October 2021, I replaced the rear discs and the pads because the inside pads were worn down to the metal and the outside pads weren't very worn at all.
So she brings it by this evening and drops it off as she said she's getting the following message on her screen "Brake System: Replace brake pads. Consult service center."
So I pulled of both rear tires and it's the same exact problem as before... the inside pads are almost gone and the outside pads look almost new... on both sides.
At this point I'm thinking calipers, but what are the odds of both of them being bad?
Any thoughts on what I could have done wrong?
Any input would be greatly appreciated.
Thanks,
Mike
Old May 27, 2022 | 05:42 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Slider pins need to be lubricated. Since the brake piston is on the inside, the caliper relies on the slider pins to pull the outside pad into the rotor. If the pins don't move freely, the caliper won't pull the outer pad.
Use Sil-Glyde grease -
Amazon Amazon
Old May 27, 2022 | 07:30 AM
Chappy's Avatar
Chappy
Use Sil-Glyde grease - https://www.amazon.com/Napa-7651346-.../dp/B0054DWS1W
Thanks, I'll see what I can find on the slide pins. Makes complete sense, I know I didn't grease them.
Old May 27, 2022 | 10:58 AM
TVPostSound's Avatar
TVPostSound
Along with the caliper lube, your daughter drags the brakes.
When one lightly touches the brakes, lets say a block before the light, the inside pad will touch the rotor, but not enough force to pull the caliper along with the outside pad.
Also check the parking brake, and verify it not too tight.
2014MCS_Miami
Jul 24, 2021 06:43 PM
alex2364
Nov 22, 2018 06:49 AM
fr0mmagna
Mar 3, 2013 02:54 PM
trentf
Dec 2, 2006 09:27 PM
onasled
Tires, Wheels, & Brakes
Apr 13, 2005 12:40 PM
