F55/F56 Touch Up Paint
Old Jun 19, 2020 | 11:41 AM
BobHMini's Avatar
BobHMini
Touch Up Paint
Good Afternoon,
Is the best source of touch up paint the MINI dealer? Also, where is the paint code located in a MINI (2015 Cooper S)?
Thank you,
Bob
Old Jun 20, 2020 | 12:44 PM
sgscomps's Avatar
sgscomps
Yes, the dealer is the best choice for touch up paint. The paint name/code isn't listed anywhere on the car your have to call your dealer with the last seven digits of your vin to get the paint code. The dealer can also check to make sure a paint stick is available if not they either have their own bodyshop or work with a reputable body shop that has access to the formula to make one. Not all paints are available, most are but if you have a rare color be prepared to have it custom mixed for you. Most paint stick are around $34 for the paint and clear coat.
Old Jun 20, 2020 | 02:13 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.mdecoder.com gives you the paint code.
Old Jun 21, 2020 | 04:13 AM
Jimmy Rustled's Avatar
Jimmy Rustled
I can mix touchup paint of still interested, I have shop with paint mixing system, cost me about $2.00 an oz to mix, On all Minis, the paint code is on the passenger side either on the firewall or on the strut tower.
Old Jun 24, 2020 | 07:51 AM
We have them and some Bavauto touch up paint. Just need that paint code that is in the door jab or by the paint color sticker.
Old Jun 29, 2020 | 03:18 PM
rtowell's Avatar
rtowell
I've had good luck with Dr. Colorchip. It works really well on small chips. https://www.drcolorchip.com/
Old Jul 3, 2020 | 03:18 AM
UnderWaterAce's Avatar
UnderWaterAce
Can you also mix spray-able paint? I have to respray a F55 JCW bumper to BRG (B22/6).
Old Jul 3, 2020 | 04:31 AM
Capt_bj's Avatar
Capt_bj
automotivetouchup.com
Old Jul 3, 2020 | 11:52 PM
UnderWaterAce
Their mix of BRG comes out extremely dark compared my paint for whatever reason.
Old Jul 4, 2020 | 05:57 AM
Walt's Avatar
Walt
Do you need to have it, maybe, fade adjusted?
Old Jul 11, 2020 | 04:52 AM
RobMac's Avatar
RobMac
I dont see BR Green on your site
Old Jul 28, 2020 | 06:03 PM
Scypio's Avatar
Scypio
Are touch-up pens worthwhile? I have a scratch (thin, but down to the base coat). MINI seems to only sell pens (base + clear). If I were to use the bottle paint, I'd use a needle anyway, so is the pen basically just that?
Or should I just go with the (cheaper) bottle and needle method?
Old Jul 29, 2020 | 10:09 AM
rtowell's Avatar
rtowell
Dr. Colorchip works really well. It works better than pens because it fills in the chip and, when done correctly, completely covers the damage. It's also pretty easy to use and is not messy.
Old Jul 31, 2020 | 11:56 AM
Scypio's Avatar
Scypio
It looks like Dr. Colorchip is advertised for chips, do you think it'll be good for scratches too? I only looked quickly at the site and I'll examine it more thoroughly later.
Thanks for the suggestion.
Dwell
Aug 13, 2010 05:45 PM
MiniWillie
Tires, Wheels, & Brakes
Sep 9, 2008 10:44 AM
JDZ
Jul 24, 2008 02:37 PM
Gromit801
Detailing 101
Mar 28, 2007 08:52 PM
