F55/F56 Errors from tack/Seedo swap
Old Jun 5, 2020 | 02:44 PM
Kurgan's Avatar
Kurgan
When I swap the tach/speedo in 2014 F56 Turbo for a refurbished one should I expect any issues (ie) error codes.
Thanks in advance.
Old Jun 6, 2020 | 08:23 AM
ASKtheteach's Avatar
ASKtheteach
The combi (gauge cluster) on my car failed about a year ago and needed to be replaced under warranty. If I recall correctly, there was coding needed. You would be surprised how much is controlled by the unit. Everything from oil level, tire pressure, and other diagnostics to the odometer, fuel level readings, and even the turn signal clicking and seatbelt “gong” are controlled by it. I drove 35 miles to the dealership “blind”. Had to use Waze in my phone to get a speed reading.
Old Jun 8, 2020 | 06:24 PM
Alpha Motoring's Avatar
Alpha Motoring
You need it coded, unless the EPROM chip is new then you will have a tamper dot and the wrong mileage.
Old Jun 11, 2020 | 07:54 AM
Kurgan's Avatar
Kurgan
All when went well. thanks for the help.
Ron_3000
Jan 25, 2020 05:07 PM
VicSkimmr
Feb 10, 2016 01:00 PM
Tektura
Mar 20, 2015 11:32 PM
Braminator
Aug 28, 2013 03:23 PM
