F55/F56 Passenger Seat Belt Warning
Old Dec 29, 2017 | 03:46 PM
Rick369's Avatar
Rick369
I own a 2016 JCW 3 door Hardtop. It currently has 19,000 miles. The front passenger seat, seat belt warning goes off after starting the car and driving above 10 mph. This happens continually even though there is no passenger in the front passenger seat. The only way I can keep the car from chiming, is to buckle the passenger front seat belt even though there is no passenger in the seat. I have an appointment on January 5, 2018 for the 2 year maintenance service and the service advisor knows about the problem. What do you think the problem is? Sensor not functioning properly? Loose wire or connector?
Has anyone else had this issue? What corrected the issue?
Old Dec 29, 2017 | 05:29 PM
Conrad_Thomaier's Avatar
Conrad_Thomaier
Do you have anything on the seat? It doesn't take too much to get those chimes going, even a full water bottle will do it.
Old Dec 29, 2017 | 09:17 PM
Rick369's Avatar
Rick369
Nothing is on the passenger front seat.
Old Dec 29, 2017 | 09:50 PM
vetsvette's Avatar
vetsvette
Moderator
Sounds like the occupancy sensor went tango uniform. Since it's under warranty let Mini fix it. The chime can also be turned off using bimmercode app or esys.
Old Dec 30, 2017 | 06:05 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Go with option B and get the app to disable all the seatbelt chimes
penguinhomey
15
Sep 30, 2023 05:53 PM
ClayLollar
Jul 13, 2013 09:06 PM
chiorozco
Jul 27, 2010 04:43 AM
sequence
Mar 4, 2009 11:36 PM
fsuscotsman
Oct 6, 2005 12:59 PM
