F55/F56 Tow Hook Thread Pattern
Old Nov 12, 2017 | 10:15 AM
honderpilot's Avatar
honderpilot
Hey everyone,
I'm looking at making my own licenceplate holder/tow hook attachment and am wondering if anyone knows what the thread pattern is on the f56.
Thanks,
honderpilot
Old Nov 12, 2017 | 01:01 PM
Conrad_Thomaier's Avatar
Conrad_Thomaier
I looked for a bolt to screw into the tow hook hole and could never find anything locally. I ended up buying a tow hook off Amazon for ~$11.
Old Nov 12, 2017 | 01:31 PM
honderpilot
I found a couple on amazon for the F56 but they all have different thread patterns. I don't wanna buy the wrong one and have to return it.
Old Nov 13, 2017 | 03:34 AM
Conrad_Thomaier
I haven't tried the tow hook on the car. Let me see if it works and what details I can get for you.
Old Nov 13, 2017 | 06:24 AM
SFMCS's Avatar
SFMCS
An easy solution is to take your tow hook (in boot) to Home Depot. In the screw and bolt section, they have a board that has all sizes (metric) that you can try and get the proper size. They will probably also have the allen head machine screw in stainless there you can buy individually.
Old Nov 13, 2017 | 06:33 AM
Do you have the factory tow hook? Just use a thread pitch measurement tool. I know the thread pitch is different on the F54+ vs the R56. I would have to go measure ours for you.
https://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Exterior/Body/Front_Bumper/
Old Nov 13, 2017 | 01:46 PM
honderpilot
That's not a bad idea. I'll do that this weekend unless someone beats me to it here.
Old Nov 13, 2017 | 02:31 PM
SFMCS's Avatar
SFMCS
I have a craven speed ring. The good thing about it that it has a large hex screw that fits the inner bumper thread. It is tapped to take a 7mm or so machine screw that you can attach just about anything (the tow ring has many positions). That maybe you best solution.
Old Nov 14, 2017 | 12:23 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
Someone just asked about this on my Q&A Thread. Unfortunately, the F56 does not use a standard thread pitch you will be able to identify at Home Depot (Edit: you might find some 3/4-8 ACME thread pitch items may be close enough and available). It is .765" diameter with 8 threads per inch. you can email or PM about getting just a bolt, or a deal on a used Platypus, or to discuss how to go about making a bolt for it. We'll be glad to help! OEM, CS Gen 3 and CS Gen 1/2 MINI
Last edited by CravenSpeed; Nov 14, 2017 at 01:18 PM. Reason: New info has come to light
Old Nov 16, 2017 | 10:54 AM
WhatV8's Avatar
WhatV8
I wonder if these threads are an ISO Trapezoidal thread, which is the metric equivalent to an imperial ACME thread?? The size noted above would likely match up to the TR20x3 size thread. The TR thread diameter for male threads is 19.764-20.000mm (0.778-0.787") and the 3mm pitch works out to be 8.47 tpi. Now you guys are going to make me pull my tow hook and measure it up to see if it really does match the TR thread form.
Old Nov 17, 2017 | 10:07 AM
J_L's Avatar
J_L
I hate to poo-poo a DIY project, but... why? There are several great kits to choose from, none of them very expensive. This is what I went with, and it's fantastic. Starts at $80. More than other plate holders, but you have unlimited adjustability- great for people who want it *exactly* right, like you and me =)
https://www.northamericanmotoring.co...ly-lights.html
http://www.usmillworks.com
Old Nov 17, 2017 | 10:20 AM
vetsvette's Avatar
vetsvette
Moderator
The millworks mount is a quality product. I had one on my R56 and liked it so much that it was one of the first things I bought for my F56. This time I went with the quick release option too.
Old Nov 17, 2017 | 12:58 PM
CravenSpeed
Vendor
I think that is a good looking option. Since I am here I have got to bring up that our F56 Platypus now features a quick release, is adjustable, has built-in hardware and I would put it up against any competitor. J-L and/or Vettesvette, I would send you our Platypus in exchange for a comparison review. Interested?
Platypus on F56 with driving Lights
Old Nov 17, 2017 | 01:55 PM
vetsvette's Avatar
vetsvette
Moderator
Sure Kellen. I would give it a try. You know I like your products.
Old Nov 17, 2017 | 02:01 PM
Capt_bj's Avatar
Capt_bj
recommendation
move to a state that doesn't require a front tag!!!!
Old Nov 17, 2017 | 02:06 PM
vetsvette's Avatar
vetsvette
Moderator
Originally Posted by Capt_bj
recommendation
Yeah. I gave up on fighting that when I got stopped for the third time in my Vette. Really hated putting a tag on that front bumper. Messes up the flow of the racing stripe.
Old Nov 17, 2017 | 07:58 PM
one2three_us's Avatar
one2three_us
To the original question, the F5x use M20 Bolt
Old Nov 20, 2017 | 10:42 AM
CravenSpeed
Vendor
Knuckle v M20x2 v M20x2.5
The F56 (all 3rd gen) thread is a bit over 19mm but not 20mm (left), it also has about 1 thread every three mm. The (middle) is an M20 with a thread every 2 mm and the (right) is M20 with a thread every 2.5mm. We make over 80 different Platypus studs like this so we can fit every current model vehicle with a threaded receptacle for one. Many cars use standard metric or imperial threads, MINI does not.
Vetsvette, I will contact you about a comparison. Thanks! -=Kellen
Old Feb 6, 2024 | 08:55 AM
Santier's Avatar
Santier
Realize this is an old thread but I did a bit of experimentation for my own tow hitch project and thought it might be nice to post the results for posterity. Long story short, after a bit a research in this thread and others, I determined the tow hook diameter is 20mm bolt with a thread pattern that is Trapezodial 3.175mm pitch. Oddly enough a 3.175 mm pitch is equivalent to 0.125" imperial and thus 6 threads per inch (TPI). So that confirms one comment mentioning it was a non-standard mix of metric and imperial measures. Additionally, I modeled this in OpenScad, printed it on my 3d printer, and was able to confirm fitment in my F56 S. Hope that helps someone else down the road.
Old May 30, 2024 | 10:27 AM
beardedfancyman's Avatar
beardedfancyman
Old or not, people are still wondering! Great info!!!
