F55/F56 JCW Side markers stoled, including connectors... Can't find it on etk
Old Jun 12, 2017 | 11:46 AM
RH56's Avatar
RH56
Hi forum members,
Yesterday my F56 JCW side markers have been ripped off, including wire harness and connectors.
It will be easy for me if they have just stole the side markers without cutting cables but it seems it was easier just to cutting it.
Here is muy problem, I have try to find the correct repair connector kit and it seems etk is not showing it:
Here are two real pictures from the side marker:
Allmagautoparts have for sell both connectors from a donnor car but each one cost USD 40 and a repair kit only cost between USD5-10
Is there anyone forum member here that could help me to find the correct part number so I can order the repair kit?
I will aprecciate your help!
Old Jun 19, 2017 | 10:55 AM
Sorry to hear this. :(
The 2 pol is going to be the closest, MINI used to have a different design for the side marker and pretty much all marker for Gen 1 and gen 2, Gen 3 looks like a different design. But still close to the same. It should fit and is snagged by the new side tongue design. Which the old design is like the plug you show, the only thing that might be different is that small triangle insert, but as you can see below the new plug should not be blocked by it. I would get 2 of these on order and the new side markers and give it a shot.
MINI changes the fix parts on the plugs vs. the original plugs but they still work as it did for my gen 1 MINI wheel arch lights.
63137368763 Left JCW
https://www.ecstuning.com/Search/SiteSearch/63137368763/
and
63137368764 Right JCW
https://www.ecstuning.com/Search/SiteSearch/63137368764/
Socket 61132359999
https://www.ecstuning.com/Search/SiteSearch/ES2798620__ES3075788/
Hope that helps.
