F55/F56 Speedometer accuracy
Old May 21, 2016 | 01:38 PM
  #26
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
How many times does this argument appear?
http://www.caranddriver.com/features...scandal-page-2
Old May 21, 2016 | 03:00 PM
  #27
neonsteve's Avatar
neonsteve
That's really interesting and the article states that the trip meter and therefore the odometer will be accurate, assuming you're running the factory tire size.
I think the reasons that the car manufacturers build in the overestimatation is ridiculous. Sell the car with an accurate speedometer... If I put bigger tires on making the actual speed higher than the displayed speed, then that's on me. Or better yet make it easily adjustable.
Old May 21, 2016 | 05:09 PM
  #28
hsautocrosser's Avatar
hsautocrosser
"I think the reasons that the car manufacturers build in the overestimatation is ridiculous. Sell the car with an accurate speedometer... If I put bigger tires on making the actual speed higher than the displayed speed, then that's on me. Or better yet make it easily adjustable."
The reasons the manufacturers do so is because they are regulated by ece-r 39 as cited and linked in the article. If they were to follow your rules they would only be able to sell cars in your kingdom. OTOH I nominate you for world leader for a day. More if you can stand it.
Old May 21, 2016 | 10:57 PM
  #29
Fly'n Brick's Avatar
Fly'n Brick
Originally Posted by rkw
No, it isn't mandated. Please give your source.
The European regulation, ECE-R 39
Old May 22, 2016 | 12:55 AM
  #30
rkw's Avatar
rkw
Here is the regulation: https://www.unece.org/fileadmin/DAM/...gs/r039r1e.pdf
You said before, "the European Union in it's infinite wisdom has mandated that speedometers show a 3 to 4 MPH difference from actual.". That is absolutely not true.
The regulation says in paragraph 5.3,
The speed indicated shall not be less than the true speed of the vehicle. At the test
speeds specified in paragraph 5.2.5. above, there shall be the following relationship
between the speed displayed (V1 ) and the true speed (V2).
0 ≤ (V1 - V2) ≤ 0.1 V2 + 4 km/h
The speed displayed is allowed to be within the range of (actual speed) and (actual speed + 10% + 4 km/h).
Old May 24, 2016 | 08:12 AM
  #31
hsautocrosser
It is not literally true but the effect of the regulation does force manufacturers to overstate speed in order to avoid it being understated with reasonable increases in tire diameter.
On-line query results:
The ECE is not the European Union but the EU did change their regulation to match.
The current US regulation appears to be +/- 10% (2005) and was previously +/- 5%.
Old May 24, 2016 | 08:29 AM
  #32
torpeau's Avatar
torpeau
Originally Posted by neonsteve
The factory tire size on my R55 is 195/55 R16. The speedometer overestimated by about 2 or 3 MPH at 60. When I installed 215/45 R17 the speedometer accuracy did not change. Now with 205/55 R16 the speedometer overestimates by only 1 or 2 MPH at 60. That's close enough for me.
And as your tires wear and when your tires are cold, especially in the winter, accuracy will change.
sam.k
Jul 15, 2016 06:11 AM
jasonl
R55 :: Clubman Talk (2008+)
11
Apr 23, 2016 06:07 PM
MiniSkoon
Apr 11, 2016 03:29 PM
penguinhomey
Apr 9, 2016 04:32 PM
AFN704
Apr 9, 2016 08:41 AM
