F55/F56 JCW pedal set
Old Apr 6, 2016 | 09:15 AM
DAVIDLEERAD's Avatar
DAVIDLEERAD
JCW pedal set
Hello everyone. So I have some credit at my local MINI dealer and I'm trying to figure it how to spend it....I know tough job! Ha!
Anyways, I was thinking about the JCW pedal set. I was wondering if anyone has upgraded to this and if there's anything tricky with switching out the accelerator. Any coding needed after this?
Thank you!
Old Apr 6, 2016 | 10:45 AM
Its the same , just the stainless steel inserts,
Manual 35426794504 KT
https://www.ecstuning.com/Mini-2014-...nterior/Pedal/
Automatic 35426794505 KT
No reflash, plug and play. Did them on my R52.
Old Apr 6, 2016 | 06:43 PM
ASKtheteach's Avatar
ASKtheteach
I's super easy. I did it on my 2012 Countryman and just did it on my new F56. At the bottom of the accelerator pedal is a small plastic cap. Pry it off, and there is an Allen screw underneath. Remove the screw and push up on the pedal to unhook it. There is a small electrical connector underneath. Disconnect the old pedal, connect the new one, hook it back on and replace the screw. Takes all of five minutes. The brake and clutch pedal covers just pull off and push on. To swap the dead pedal, pry out the old one with a small screwdriver and snap the new one in. Super easy to do, but the stainless pedals make a huge difference.
Old Apr 7, 2016 | 03:47 AM
DAVIDLEERAD
Thanks so much for the instructions!! 👍
Old Apr 7, 2016 | 05:24 AM
Yea, its pretty much plug and play , just slid on the new pedal covers, dead pedal insert ( out one out from the bottom ), and that accelerator pedal hook up.
Old Apr 11, 2016 | 10:14 PM
MoJo4Twenty's Avatar
MoJo4Twenty
Funny how you don't really think you need anything else for your car. Until, you see it on NAM. Now it's definitely on the want list.
Old Apr 16, 2016 | 06:36 AM
watchluvr4ever's Avatar
watchluvr4ever
Had them in two out of three MINI's I've owned and found I prefer the standard rubber pedals more. Living in Michigan I found sometimes those metal pedals get slick when wet from rain or snow.
Old Apr 16, 2016 | 05:49 PM
hammerhands's Avatar
hammerhands
I miss having stainless steel.
What is the mechanism in the gas pedal?
joelmz
Jan 12, 2017 09:48 PM
JCW_Coupe
Feb 26, 2016 05:33 AM
Feb 22, 2016 02:54 PM
dube53
Feb 18, 2016 06:50 PM
Feb 16, 2016 08:26 AM
