F55/F56 Okay, What File Formats will my 2015 HK POS Radio Really Play?
Old Mar 11, 2015 | 01:29 PM
  #26
TheBigNewt's Avatar
TheBigNewt
Originally Posted by hammerhands
I think you can download AAC plus non-protected copies of anything you have bought from ITunes that they still have available. You should back up your files first, you may be surprised at what they no longer carry. It says something about subscribing to Itunes Match, now, but I don't know, I would give it go once you've backed up your files.
An easy way to convert all your music in ITunes is to set the default format to your target format, then you can click "Create 256kb MP3 version." You should be able to do that on everything in your library. I'm not sure how that would work for DRM files.
I didn't know that. The OP's iTunes is ripped to Apple Lossless and he wants in 256kb so he can play it on a USB in his Mini. But he still wants the Lossless copys to play from iTunes on his stereo. Would your suggestion accomplish that, or would it just convert all the songs to 256 leaving no Lossless? If it does do what he wants how does he get just the 256 songs onto the USB, hunt and peck one by one?
Old Mar 11, 2015 | 04:34 PM
  #27
hammerhands's Avatar
hammerhands
I'm addressing posts 8 & 11.
I'm suggesting temporarily changing the default format, then I would change it back to lossless.
You can keep the files separate, there's a couple of ways to do that.
I think you can sort by audio format, if you add that column, let me check...yes you can add "Kind" and "Bitrate"...that would allow you to move the non-lossless files to a different directory. [You can grab the lines from the ITunes song list and drag them to a new folder.] [Then remove them from the library without deleting the files!]
The way I would do it, if I was doing this on a Mac, you can setup a new Library, re-import the Lossless files, without moving the files into the new Library [I think the option is "Add Files to Library"] and then create your new files. Then you can switch back to the old Library.
The problem with doing that on a PC is that if you have added album art or used ITunes to edit your tags, you will lose that info. On the Mac it seems to write that info to the file.
That's a trick I've found on the PC, if you have your lossless files in a different directory and edit the tags, then click on "Create an Apple Lossless duplicate" the new file will have the new tags, and maybe the artwork too.
Old Mar 11, 2015 | 05:13 PM
  #28
hammerhands
I think you can download AAC plus non-protected copies of anything you have bought from ITunes thoat they still have available.
Yeah, I just tried this, it seems to still work.
You go to the ITunes Store and login, at the bottom there is "Featured" and "Purchases". You should be able to download the files there if they are no longer in your library.
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
patsum
26
May 29, 2021 06:29 PM
Olenska
Sep 21, 2015 12:36 PM
paul7878
Sep 14, 2015 07:44 AM
Sep 1, 2015 04:39 PM
