F55/F56 Oil Compatibility
Oil Compatibility
Alright.... it is almost time for my 2nd Oil Change.
1st Round i used Genuine Mini Oil at about $7.50 a quart. = $37.50 for 5 Qts.
I want to find something from Local Wal Mart and Auto parts store that comes in a Jug.
I know Mobil1 and Castrol have their 0w40 Euro Formula Oil, that goes for about $22 a Jug. Are both of these compatible with our Mini F56?
Driving about 75Miles a day, I change my oil quite often. Just trying to save wherever possible if you know what i mean.
So can anyone CONFIRM that the above 2 is a APPROVED oil to use in our engine?
I think those oils are OK, pretty sure of the Mobil 1. Something about level 1 or grade 1 Euro rating or something. This has been covered a bunch on the R56 threads. 0-40W is the key thing I think.
If you have a 2014 MINI Hardtop:
BMW Longlife-01
BMW Longlife-01 FE
0w-30, 0w-40, 5w-30, and 5w-40 are ok.
Mobil 1 0w-40 European Car Formula meets BMW Longlife-01. Check the label on the back before buying.
Source: owner's manual at MINIUSA.com and label on Mobil 1 in my garage. I spent hours finding a reasonably priced oil that would satisfy both the BMW and VW requirements for the cars in our garage. Then I used a dump trunk to unload my head.
BMW Longlife-01
BMW Longlife-01 FE
if your car is under factory warranty and you are doing your own oil changes, the oil needs to meet mini specs
also keep a log of the miles and date of change with the receipts for the oil and filters
Are these MINI requirements that are written somewhere?
verbal advise from my SA after i told him i intended to do my own oil changes more frequently than the OBC indicated
i got the same advise from my GMC SA when i bought my sonoma p/u truck
"BMW LL-01, oils should also meet ACEA A3/B3 specs." Yep. We have the oil filters also and the socket.
We have a F56 Oil change DIY here, note the oil capacities have been updated as well as the kits, there is F56 Cooper Kit and F56 Cooper S kit.
https://www.northamericanmotoring.co...rocedures.html
Bruce/Fl
Aug 28, 2015 11:59 AM
AdrenaliNate
Aug 24, 2015 12:37 PM
