F55/F56 Tires
Old Nov 6, 2014 | 09:27 AM
Steveo9's Avatar
Steveo9
Tires
Has anyone changed the stock 17" tires. I am looking to put 215/40/17" tires on mine.
Old Nov 6, 2014 | 12:52 PM
bneer's Avatar
bneer
I have been thinking about changing to 215/45/17 myself. Maybe someone will share some insight. I have changed the tire sets several times but never to a 215.
Old Nov 6, 2014 | 01:04 PM
MikewithaMini's Avatar
MikewithaMini
Very common swap. I run it with a slight lowering from NM springs with Konis. No rubs, no issues. A little more comfortable a ride than with 205's I think.
Old Nov 6, 2014 | 01:15 PM
rustof's Avatar
rustof
I have never swapped my summer 17"s with anything else but 205/45 but I will add my .02 cents from my expierence recently changing my winter tires. I have a set of 15" rims and bought some NITTO SN2 off tire buyer for a song (270 for 4), and wanted them installed at a local dealer, a quote of 30 per tire installed and balance by my local premium tire shop had me looking elsewhere though. I thought I could save some cash and just have Tires Plus change them out... they wanted 180, just to mount and balance a set of tires. Mouth open, I told the service attendant to sell that ketchup pop-sickle to another schmuck, and left. Across the street, at an NTB store, got them all installed and balanced for 90 flat.
BTW, I didn't think that a tire shop would install oversize tires on consumer vehicles, is that still the case or running a 215 on a 205 rim too negligible to make mounting those tires unsafe?
Old Nov 6, 2014 | 01:26 PM
MikewithaMini
At Discount they are an optional size for the application, so they should install them. Dealer will not. I've had no problems getting 215s swapped or installed on 2 separate cars at Discount. If you live in the sticks, Tire Rack may be a great alternative to get what you want.
Old Nov 6, 2014 | 02:27 PM
Steveo9's Avatar
Steveo9
Tires
I am going to lower profile so ride will be rougher but handling better. Both my dealer and Discount Tire says 215/40/17 will be fine and Discount will install them.
Thanks for your replies. I will let you know how they turn out. I am probably going with the Nitto Neo Gen.
Old Nov 6, 2014 | 02:49 PM
Chad R. Cook's Avatar
Chad R. Cook
Originally Posted by Steveo9
I am going to lower profile so ride will be rougher but handling better. Both my dealer and Discount Tire says 215/40/17 will be fine and Discount will install them. Thanks for your replies. I will let you know how they turn out. I am probably going with the Nitto Neo Gen.
Don't forget to post photos too!
Old Nov 6, 2014 | 04:51 PM
randomquickness's Avatar
randomquickness
Just a suggestion, for improved handling without sacrificing comfort, why not run a grippier tire instead of a lower profile? I'm hoping to ditch my 17" runcraps for a set of 16" with hankook R-S3s.
Old Nov 6, 2014 | 05:29 PM
sacandagadano's Avatar
sacandagadano
I ditched factory runflats after 500 miles,they were loud and harsh. Went with Hankook S1 Noble 2 (UHP all season)215/45-17. NO mounting or clearence issues at all. I will run these till Thanksgiving then mount my Tirerack winter pkg.(195/55-16 Blizzak WS80 on 100$ alloys)No 16 inch steelies available for our F-56. Lose the runflats,you will be happy!!
Old Nov 6, 2014 | 05:35 PM
Steveo9's Avatar
Steveo9
Run flats
Thanks for the info. I've got only a little over 200 miles on mine so we are on the same page. I'll let you know how the lower profile works out.
Old Nov 6, 2014 | 05:41 PM
Steveo9's Avatar
Steveo9
Also I went with Nitto Neo Gen. $490 installed including tax. The smaller diameter will throw off the speedometer but only by 2%.
Old Nov 10, 2014 | 05:25 PM
Steveo9's Avatar
Steveo9
I had the 215/40/17 Nitto Neo Gen tires put on today. So far much better than standard run flats.
Old Nov 10, 2014 | 06:08 PM
sacandagadano
Good deal,you will never look back!! Play with your tire pressure,start high adjust down.You will find the best ride.
Old Nov 10, 2014 | 07:24 PM
Steveo9's Avatar
Steveo9
Going to lower profile and wider tire turned out great. 215/40/17 is the tire for tho car.
Old Nov 11, 2014 | 12:53 PM
Chad R. Cook
does it change your speedo accuracy?
Old Nov 11, 2014 | 01:39 PM
Steveo9's Avatar
Steveo9
It does affect the speedometer but only by 2% which is not insignificant but acceptable to me. Check out the site below. Go to the tire size comparison. Put in current tire size and optional tire size. It will tell you everything.
http://tire-size-conversion.com/tire-size-calculator/
Old Nov 11, 2014 | 01:46 PM
Chad R. Cook
It does affect the speedometer but only by 2% which is not insignificant but acceptable to me. Check out the site below. Go to the tire size comparison. Put in current tire size and optional tire size. It will tell you everything. http://tire-size-conversion.com/tire-size-calculator/
so 215/40 is better than 225/40? It show both sizes be equivalent in that calculator you shared.
Old Nov 11, 2014 | 02:41 PM
Steveo9's Avatar
Steveo9
225 will fit the 7" rim but are pushing the limit. Using a tire that is too wide for the rim (even marginally) will negatively affect handling. Also 225/40/17 is a very difficult and expensive tire size to find.
Old Nov 11, 2014 | 03:44 PM
Chad R. Cook
thank you. I am very interested in trying the 215/40 size!
Old Nov 11, 2014 | 04:31 PM
TX1911fan's Avatar
TX1911fan
I find only two tires on Discount Tire's site in 215/40/17. There are tons in the 214/45/17 size. Opinions on that size?
Old Nov 11, 2014 | 05:17 PM
Steveo9's Avatar
Steveo9
They had many choices when I stopped by the store. More then on website. Tire Rack has 10 or so.
Old Nov 11, 2014 | 07:01 PM
Steveo9's Avatar
Steveo9
I attached a couple of pictures with the new tires (hopefully).
Attached Thumbnails Tires-wp_20141111_15_18_33_pro.jpg   Tires-wp_20141111_15_18_46_pro.jpg
Old Nov 13, 2014 | 12:48 PM
ColoradoF56's Avatar
ColoradoF56
I'm looking to purchase a set of winter wheels and tires but I'm worried about the TPMS. How did you deal with finding the right TPMS that will work with the car?
Old Nov 13, 2014 | 03:06 PM
QBear's Avatar
QBear
Talk to someone who "knows their stuff". My suggestion would be Eric (Ext. 4314) at Tire Rack.
I just installed my winter setup from the Tire Rack today, and all's working just as it should (including TPMS).
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
