F55/F56 OBD II DashCommand settings
Old Oct 12, 2014 | 08:52 PM
Crimguy's Avatar
Crimguy
Anyone have the definitive settings for the MCS?
Old Oct 13, 2014 | 10:26 AM
hammerhands's Avatar
hammerhands
You can find many of them in this document, like the gear ratios.
You have to multiply them by the final gear ratio.
http://s3.motoringfile.com.s3.amazon...1/US-Specs.pdf
I asked MINI for Brake Specific Fuel Consumption and Volumetric Efficiency, but they did not give them to me.
I will figure out Minimum Engine Speed and Shift Point by experiment.
There's a description of the settings here:
https://www.palmerperformance.com/do...ser_Manual.pdf
Shift Point – This value is used for the gear calculations. Set this value to the most economical shift RPM.
https://www.northamericanmotoring.co...fications.html
Old Oct 29, 2014 | 03:19 AM
hammerhands
OK, please help me, where is the OBDII interface?
In the manual it has an arrow vaguely pointed above the dead pedal.
Old Oct 29, 2014 | 08:29 AM
Crimguy's Avatar
Crimguy
It is a downward-facing female port above the dead pedal. Stick your hand under the dashboard in that area and feel around for it. I used my iPhone's front-facing camera to look underneath and was able to spot it fairly easily. Dimensions are approximately 1cm x 4cm.
Old Oct 29, 2014 | 09:01 AM
Grizld700's Avatar
Grizld700
Thats pretty much the area. Its on that side. Just ahead of where your knee might sit. It has a little cover on it. Just slide the cover off and plug it in!
Old Oct 29, 2014 | 09:21 AM
hammerhands
I meant to link this PDF I think.
http://www.autoblog.gr/wp-content/up...ew_MINI_EN.pdf
Old Oct 29, 2014 | 10:14 AM
Crimguy's Avatar
Crimguy
Yours had a cover? <feeling ripped off ;-)>
Old Oct 29, 2014 | 10:24 AM
hammerhands
Thank you, great advice.
Mine didn't have a cover on it [that's an R56 thing?], I'm not sure why I couldn't find it by feel last night.
Here's a photo, I'm not sure if it will be useful to anyone else, it's a bit blurry. What's important is that little metal plate beside it with a tab that hangs down, that's pretty easy to find when you feel around down there. The port is just to the left.
Old Oct 30, 2014 | 03:09 AM
hammerhands
When the speedometer was reading 60 km/h, the iPod said I was at 54 km/h.
What is it calculating, or is the speedometer wrong?
Old Oct 30, 2014 | 11:57 PM
hammerhands
I don't think it's calculating it. It says "vehicle speed sensor" in the Data Grid screen.
The speedometer must be purposefully set fast. I will have to compare it to my GPS.
But the odometer has to be correct, by law?
I tried to get a number for "Shift point" tonight. I put the car in green mode and crawled down the road. It seems to shift between 2000 and 1750, shifting sooner in the higher gears.
I was eyeballing it the day before and it seemed to be 1750.
I'm not sure what number to use.
Old Oct 31, 2014 | 08:40 AM
Crimguy's Avatar
Crimguy
Dash command has settings for wheel size. That probably has to be entered for an accurate reading. I was within 1mph on my car.
Old Oct 31, 2014 | 06:43 PM
hammerhands
I need to check everything again. What is VSS measuring?
It counts the rotation of something in the transmission.
Is the speed generated by the instrument or by calculation?
Speedometer & Cruise Control 100 km/h
Vehicle Speed Sensor 95 km/h
GPS 98 km/h
What's weird is that it is not out a percentage, it's just out.
At 60km/h on the speedometer it showed 54km/h.
Old Nov 1, 2014 | 01:18 AM
hammerhands
Tire size is going to change as the tire wears.
Old Nov 1, 2014 | 02:06 PM
hammerhands
Ok, I tested it again, it is out some percentage.
I chose 1880 as the Shift Point in my 3-Cyl.
I put in 0.55 for BFSC. Can that be calculated?
Old Nov 5, 2014 | 08:53 AM
hammerhands
I also chose 1150 as the minimum RPM in gear.
One of the coolest things is that it shows the remaining fuel as a percentage. I will have to see if it has the oil level and tire pressures somewhere.
No oil level, no voltage, no tire pressure.
I have a Dual bluetooth GPS hooked up, it works with Google maps [or it was working,
I will have to double check] but it doesn't fill in the GPS coordinates in DashCommand.
Oh, there's a "GPS fix for iOS 8" update for DashCommand today, let's try it out! ...
It works.
Old Nov 5, 2014 | 10:24 AM
Crimguy's Avatar
Crimguy
I think I settled on 0.40 for bsfc
Old Nov 5, 2014 | 12:22 PM
hp79's Avatar
hp79
Are we able to actually reprogram the shift RPMs? Or is that some setting in the app itself to accurately read the raw data coming out?
I have a cheap ELM327 ODB2 bluetooth adapter which works well with an Android app called Torque Pro. Is DashCommand better than TorquePro?
Old Nov 5, 2014 | 02:41 PM
hammerhands
The shift RPM setting is a number that DashCommand uses for calculations.
It doesn't program anything. It shows various gauges, logs data and reads engine codes.
What does Torque Pro do?
Old Nov 5, 2014 | 02:46 PM
hp79's Avatar
hp79
Ahh.. I see. Torque Pro just reads data from your ODB2 reader. It can display tons of information, and the layout can be customized to the ones you are only interested in.
I use it like this on my Mazda.
Old Nov 8, 2014 | 10:25 PM
Crimguy's Avatar
Crimguy
Looks like Dash Command is similar to Torque Pro but with a bit more customization.
Waszak
Oct 21, 2017 05:55 PM
dscott90000
Sep 9, 2015 07:55 AM
mimaal
Sep 4, 2015 09:09 AM
Wesley Hardy
MINI Collectibles
Sep 3, 2015 06:51 PM
tag1260
Sep 2, 2015 07:42 PM
