F55/F56 rear hatch light
Old Aug 23, 2014 | 08:22 AM
Mrdi's Avatar
Mrdi
rear hatch light
Any way to turn off the rear hatch light when the hatch is open?
It is the light on the passenger side just forward of the rear tail light.
The hatch is open for over an hour when I am washing the vehicle.
Old Aug 23, 2014 | 08:30 AM
MasterYoda's Avatar
MasterYoda
Disconnect the bulb or find the switch that turns in on and tape it down.
Old Aug 24, 2014 | 07:21 AM
darex's Avatar
darex
That bulb gets extremely hot! I swapped mine out for an LED bulb. It should have been LED from the start. All the rest are!
Old Aug 24, 2014 | 08:38 AM
Mrdi's Avatar
Mrdi
Hot means amps = battery drain.
Old Aug 24, 2014 | 10:45 AM
torpeau's Avatar
torpeau
I leave the hatch open almost all the time the car sits in the garage, and the light goes off w/in 15 minutes.
Old Nov 9, 2014 | 10:45 PM
hp79's Avatar
hp79
Can you tell me what size the bulb is? What shape? Thanks!
I also swapped my trunk light on my Mazda CX-5. It's nice to have a very low power LED light back there.
Old Nov 28, 2014 | 10:40 PM
hp79's Avatar
hp79
I was having trouble pulling that housing out, and finally got it out. The trick is to open the soft panel (to access brake lights) off first, and then put your hand in there, use your finger to unlock the clip from the back towards the front of the car. See pics so you don't snap them like I almost did.
Press the clip towards the front (1) while pressing it out (2).
I have the bulbs on order, and will definitely replace this bulb. It gets so hot, which uses up a lot of battery and doesn't seem to turn off for a long time.
If you want to keep it off while working on it, pull fuse 70.
Attached Thumbnails rear hatch light-pb281508.jpg   rear hatch light-pb281511.jpg
Toolman
Jan 20, 2016 06:50 AM
Dec 23, 2015 10:36 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
