F55/F56 F56 Spring/coilover install?
Old May 28, 2021 | 09:20 AM
  #51
J_L's Avatar
J_L
Rear upper strut bolts- 21 lb ft. It's in the Haynes manual, worth the cost.
Old May 28, 2021 | 10:29 AM
  #52
Juice84's Avatar
Juice84
I don't see Haynes manual for f series cars on their website. Is that for the 'hat' to the strut or the strut to the body (I actually need both)?
Old May 28, 2021 | 11:28 AM
  #53
J_L's Avatar
J_L
that's the hat to the body.
Strut to hat is 22.
Lower strut bolt 114.
I can't remember where I got mine, but pretty sure it was in the US. Though now looks like everything is UK only. This came up on a google search, not a terrible price:
https://www.abebooks.com/MINI-petrol...hoCNJYQAvD_BwE
Old May 28, 2021 | 01:45 PM
  #54
Juice84's Avatar
Juice84
Strut to hat is 22.
Thanks! I ordered myself a copy, cheaper then what I could find in the states even with the shipping cost from the UK.
Old Sep 12, 2023 | 05:24 AM
  #55
MINIBMAN's Avatar
MINIBMAN
Originally Posted by honderpilot
+/- 10%. They should be pretty close. I forgot to add them. I'll do it tonight.
Edit: Here you go
front
11ft lbs+ quarter turn top bolt
44ft lbs main nut assemble everything top hat to strut shaft
48lbs sway bar links and shock
52ft lbs+quarter turn pinch bolt
rear
48 lbs sway bar links
133 ft lbs shock bottom trailing arm (lower shock bolt)
66ft lbs carrier disconnect with lower control arm-
Do you think my 2024 JCW would be the same specs?
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
1chaos52
Aug 24, 2015 01:28 PM
