F55/F56 F56 Oil Change Procedures
Old May 18, 2015 | 04:37 AM
  #76
runswithsizzers's Avatar
runswithsizzers
Originally Posted by Drivehard
Some added info on the statement "MINI recommends Castrol"
Recently BMW /MINI changed there world wide supplier of oil. SHELL is now their world wide supplier. So yes oil your stickers oil caps and owners manuals are out dated.
But BRAND of oil has nothing to do with it. It is specification. LL-01 is the spec. And weight is a preference. 5w30 or 0w40 in the correct specification is just fine. Hence why so many on this forum use MOBIL 1 LL-01 0w40 European blend. There are others but the Mobil 1 is easy to get at Walmart on sale for 24.00 for a 5 quart jug.
Carry on with conversation. Just adding my tidbit.
Sent from my iPad using NAMotoring
I would say my Owner's Manual is more than "out of date" - it's just plain wrong. MINI has never recommended any product with Castrol's name on it for a complete oil change for my car.
Furthermore, my Owner's Manual says to use oil with an API service rating of SM or higher" - when their own MINI brand oil has an API service rating of only SL. This is true of both the previous MINI oil made by Castrol (p/n 07 51 0 143 829) and the newer Shell-made oil (p/n: 83 21 2 365 947).
And yes, LL-01 is an important specification, but there are other specifications, too. The ACEA spec is probably equally important.
My American-market owner's manual (2010) doesn't give a recommendation for a minimum ACEA rating, but I'm told the UK version of the owner's manual recommends "ACEA A3/B3" The older (Castrol-made) MINI oil is rated ACEA A3/B3; the newer MINI oil, made by Shell is ACEA A3/B4.
For me, it's 6 hours, round trip to the nearest MINI dealer. It's frustrating to know there are probably half a dozen different oils on the shelf of my local auto parts store that will work just fine in my car, but MINI doesn't give me the information I need to figure out which one.
Now that MINI is in bed with Shell, the nearest MINI-equivalent oil may be PENNZOIL PLATINUM® EURO SAE 5W-30 FULL SYNTHETIC MOTOR OIL. Specs here.
When considering non-MINI brands, read the labels carefully. There is a difference between meeting a specification, "approved" (by BMW/MINI), and "recommended" (by the oil manufacturer).
Old May 18, 2015 | 06:53 AM
  #77
They went from Castrol Euro to Shell Euro. Old Castorl stuff is now NLA. Both Meet BMW / MINI LL-01. If you pop in the old part number to our site it goes to the new Black Bottle green stripe Shell Euro 5w-30.
Old Jul 3, 2015 | 08:07 AM
  #78
Lucas63's Avatar
Lucas63
There is some good info here but a few things are left unanswered, I think.
Does anyone know the torque for the oil filter housing and drain plug, also the oil pan drain plug?
What are the oil choices that meet the specs and are LLo1? There are some products mentioned here and there. Are there more? Is the oil spec any different between the 4 and 3 cylinder?
I'm thinking a sticky needs to be posted with approved oil listings and maybe another with general info on other maintenance jobs like the above mentioned torque because it will be awhile before a Bentley Manual will be published.
Old Jul 5, 2015 | 02:08 AM
  #79
blue al's Avatar
blue al
LL04 spec is what I always look at in the UK
As its newer than LL01 I assumed more current
Old Jul 6, 2015 | 03:26 AM
  #80
Lucas63's Avatar
Lucas63
I've read that the difference has to do with sulfur in fuel
LL4 is for low sulfur fuel, like what is used in the EU
LL1 is for high sulfur fuel, like what is used in the USA
Old Jul 6, 2015 | 08:39 AM
  #81
papawhiskey's Avatar
papawhiskey
Don't know about either drain plug but the plastic cap is 18 ft lbs or 25 Nm.
Old Jul 6, 2015 | 08:46 AM
  #82
Lucas63's Avatar
Lucas63
I forgot about that one, good info, thanks
Old Jul 6, 2015 | 09:08 AM
  #83
Lucas63's Avatar
Lucas63
As an FYI just spoke to Castrol. In the their aftermarket products they do not sell a 5W30 that is LL01 and API SM or SN rated.
Old Jul 6, 2015 | 10:19 AM
  #84
Lucas63's Avatar
Lucas63
Valvoline Synpower MST
Found that Valvoline makes an oil, Synpower MST in 5W30 that is LL01 with an API of SN/SM. Their customer service says it's sold in the USA but I can't find anyone who sells it. Special order probably means special price.
File Type: pdf
Old Jul 6, 2015 | 10:43 AM
  #85
Lucas63's Avatar
Lucas63
Is this correct? Isn't the API rating supposed to be SM or SN. Castrol said the SL rating would not be correct. SL would cover older models. The 2015 owners manual for the Cooper Hardtop says API SM or superior, which would be SN
Old Jul 6, 2015 | 10:45 AM
  #86
That is the correct stuff ( Shell Euro ) the same stuff MINI stocks and uses at the dealerships.
The Castrol Euro was SS to the New Shell Euro.
Old Aug 12, 2015 | 05:28 AM
  #87
xpunisherx's Avatar
xpunisherx
I've been using 5W-30 Mobil 1, but Mini says 0W-30, 0W-40 or 5W-40 are acceptable also.
Papa....can you point me in the right direction where i could find the list of approved oil (and oil weights) approved by MINI? Thanks.
Old Aug 12, 2015 | 06:28 AM
  #88
xpunisherx's Avatar
xpunisherx
Disregard...I found it here...
http://www.miniusa.com/content/miniu...ml#maintenance
Old Sep 11, 2015 | 02:49 PM
  #89
BRP27's Avatar
BRP27
1st Oil Change
Changed the oil today and it was pretty straight forward. I noticed that the the engine oil drain plug (17mm ) did not have the brass "gasket" on it from the factory. I checked to see if it was stuck on the sump pan and it was not stuck there and had not been installed . Walmart does this as a standard practice
The filter housing design is pretty cool, has a drain and the filter element snaps in the housing . BMW filter kit has the O ring for the housing, a new housing drain plug and the brass gasket for the drain plug omitted by the factory.
It took 5 quarts to fill it to 100%.
Kudos to jtoddpaul for the original post of the oil change procedure.
Old Sep 11, 2015 | 04:29 PM
  #90
dcummer's Avatar
dcummer
On mine the factory used an aluminum sealing washer - it was thoroughly stuck to the oil pan. Next time you have yours off maybe look for an alum washer - I'll bet you are double-stacked now.
Old Sep 11, 2015 | 04:47 PM
  #91
BRP27's Avatar
BRP27
I looked at it close and used a pick looking for a seam but next change I will check it again. Thanks for the tip that its aluminum
Old Sep 14, 2015 | 06:23 AM
  #92
Interesting , must used aluminum then went to copper.
Old Sep 15, 2015 | 09:16 PM
  #93
MidnightF56's Avatar
MidnightF56
Any thoughts on doing the oil change with LIQUI MOLY?
Supposed to be really great German oil...
Old Sep 16, 2015 | 05:41 AM
  #94
We carry it , good stuff, and it under the drop down for oil. Looks for more all in one kits here soon.
Old Mar 16, 2016 | 03:37 PM
  #95
Sneakz's Avatar
Sneakz
I'm doing my first oil service soon in between the scheduled services and in Canada oil choices are definitely limited. Basically they are
Mobil 1 0W-40 European Car Formula
Castrol EDGE 0W-30 A3/B4 aka German Castrol
Castrol EDGE 0W-40 A3/B4 Made in Germany or Belgium depending on batch
All are BMW LL-01 rated and both 0W-40 oils are API SN rated while the 0W-30 Castrol is API SL. As far as I know, the Mobil 1 is a group III oil according to bobistheoilguy forums while both Castrol synthetics are group IV full synthetics.
Locally the Castrol 0W-40 seems to be the easiest to find at a decent price. (Paid $36.60 CAD). My 5L jug was made in Belgium so I'm going to try that out and see how it goes.
Old Mar 16, 2016 | 03:54 PM
  #96
Chazman's Avatar
Chazman
I've been using the same Castrol 0W-40 on my MCS and it's been working just fine with no issues - almost 50,000 miles now.
Old Mar 16, 2016 | 04:06 PM
  #97
Sneakz's Avatar
Sneakz
That's good to hear.
Old Jun 5, 2016 | 09:02 PM
  #98
qualt's Avatar
qualt
I just replaced my previous Mini with a new 2017 JCW convertible, and when I raised it on a hoist too see what it looked like underneath, I noticed that the oil change access panels were no longer there.
It appears you must now remove the entire under engine shield/cover to do almost anything under the engine; which of course would include changing the oil..... First Mini eliminated dipstick and now the oil drain access panels, is the hood/bonnet release next?
Old Jun 6, 2016 | 06:06 AM
  #99
02fanatic's Avatar
02fanatic
5W-40 LubroMoly is all my BMW mechanic uses in all of his BMW's and MINI's. I am thinking of possibly going with this. Anyone else use this oil?
Another question: May I assume the oil change procedure for the JCW is the same as for the MCS?...they are both 2.0L engines. 5.3L capacity? I might have missed it in this thread, but just checking.
I am thinking of changing my own oil this summer (either Lubro or MINI synthetic)....right now I'm at 628 miles LOL! But I'm at 1 year since picking it up new.
Thanks,
John
Old Jun 7, 2016 | 05:14 PM
  #100
justindavis's Avatar
justindavis
Thanks,
John
600 miles in a year, now that's awesome!!
