F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Swaybar link bolt snapped
Old Mar 21, 2026 | 08:00 AM
blue al's Avatar
blue al
This has snapped 07119908026 Hexalobular socket screw
so do I need a new trailing arm ?
or can I rivnut it ?
33308842878
Or
33 30 8 854 116
or would you try and drill it out, or attempt to rivnut it ?
Old Mar 24, 2026 | 08:16 AM
thefarside's Avatar
thefarside
That sucks!
Got access to a MIG welder? Weld a nut to it. otherwise drill, and if need be, install a helicoil.
Guessing that attempting to extract is less hassle than replacing the arm.
I'm a bit wary of the rivnut approach - no experience with them
Allmag has clean used arms, no affiliation, just a satisfied customer
Best of luck!
Old Mar 24, 2026 | 11:57 AM
Drill and try to extract. Something like this should work.
https://www.ecstuning.com/b-titan-pa.../ttn16013~ttn/
Old Mar 25, 2026 | 10:21 AM
WhatV8's Avatar
WhatV8
If you go the drill/extract route, I would strongly suggest getting a center punch, so the drill stays in the center of the screw you are trying to extract. Also, start with a much smaller bit first to drill a pilot hole and step up to the final size for the extractor bit. Good luck!
Old Apr 3, 2026 | 02:49 PM
blue al's Avatar
blue al
Man with welding kit and talent sorted it for me
Old May 4, 2026 | 03:35 PM
FueIdsofFire's Avatar
FueIdsofFire
having the same issues
FueIdsofFire
can you explain how you got the solution
yyj3869
Sep 19, 2024 10:51 AM
Ronstang
Aug 28, 2018 06:05 PM
ijourneaux
Aug 20, 2018 06:52 PM
juchong
Suspension
69
Jul 31, 2018 08:23 AM
NAProf
Suspension
19
Sep 17, 2012 09:12 PM
