F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
2017 F56 JCW clutch pedal sticking intermittently help!
Old May 29, 2023 | 07:12 PM
jcubwf56's Avatar
jcubwf56
Apologizes if this has been discussed, I searched and couldn’t mind much info. The clutch pedal in my JCW occasionally sticks to the floor for a half second or so. Usually after hard driving. It’s happened maybe a dozen times over the past couple months, pretty infrequent. At first I thought it was getting hung up on the floor mat for just a moment but that wasn’t it. I’m not the most mechanically inclined, but I’m wondering if it could be something to do with transmission fluid? I’ve owned the car since October in NJ so I’m only just starting to see how the car deals in warmer weather. Any thoughts? Thanks!!
2017 hardtop jcw
6 speed manual
bootmod3 stage 1
45,000 miles
Old May 30, 2023 | 01:52 PM
Hello,
https://www.realoem.com/bmw/enUS/sho...diagId=35_0531
Maybe the spring # 5
https://www.ecstuning.com/b-genuine-...g/35306860671/
or worn, sticky bushings? # 6
https://www.ecstuning.com/Search/Sit...h/35006873503/
Only other thing i can think of is a stuck slave cylinder. It would be in the clutch pedal or hydraulic clutch line.
Old Jul 17, 2023 | 04:12 PM
jcubwf56's Avatar
jcubwf56
Update: been traveling so I haven’t driven the car much. Went out for a short drive today and the clutch was slow to return back after pressing it. I drive home, turned off the car, and pumped the clutch a few times and it stuck to the floor and wouldn’t return. I manually pulled on it and heard a hissing noise as I pulled the clutch up. Any thoughts?? It was pretty hot out today ~95 degrees.
rmepilot
Sep 3, 2021 08:48 AM
fjork_duf
Mar 11, 2017 06:26 PM
Zookeeper
Factory JCW Talk (2009+)
236
Jun 26, 2016 07:48 PM
greentimemachine
Nov 2, 2011 07:51 AM
Plumb757
16
Apr 28, 2011 02:15 PM
