F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
2012 Mini Cooper engine codes?
Old May 21, 2023 | 02:04 PM
Jpiccott's Avatar
Jpiccott
New too the site and wondering if anyone has had a load of codes
Replaced rear speed sensor and still showing a problem
Old May 21, 2023 | 02:12 PM
Jpiccott's Avatar
Jpiccott
And what is the fix?
and what is the fix?
Old May 21, 2023 | 03:37 PM
DenisMcG's Avatar
DenisMcG
If you click the white arrow next to the error, it will take you to a suggested repair page. Basically, check the wire for the left rear speed sensor (ABS sensor). If the wire looks fine, then replace the sensor. Most of the other codes are likely associated with the speed sensor problem. Clear as many codes as you can and go for a drive.
Old May 21, 2023 | 03:40 PM
Jpiccott's Avatar
Jpiccott
replaced sensor checked all wiring cleared the code and still everything is the same as before
ZRXChris
R55 :: Clubman Talk (2008+)
Nov 14, 2019 04:51 PM
clark5592
Sep 25, 2019 10:36 AM
TonySyn
Dec 9, 2018 05:22 AM
Saltysalt
16
Jul 17, 2013 09:12 AM
