2016 F54S - Having issues with vibration at idle when engine fan kicks on
Hey all,
I've searched but could not find much information in regards to an issue I've been experiencing.
I have 16 F54 S that has about ~35k miles on it at the moment.
The car has been maintained properly and drives perfectly fine.. EXCEPT for when you are sitting at a stop light or at a parking lot with engine fully warmed up.
After a few minutes of idling, there comes, what sounds like to be high speed fan kicks on and the car will begin to vibrate in a very consistent in a rhythmic fashion "Brrr - Pause - Brrr - Pause - Brrr - Pause - Brrr"....
At first, I thought the car was actually misfiring as the vibration was evident through the seat and with the sound.
But as soon as the fan slows down and turns off, the car will idle smoothly.
I searched around but could not find thread on similar issue, if anyone can chime in and tip me on what is actually wrong with the car, it would be much appreciated!
Thank you all in advance-
It may be a bad bearing in the fan itself.
Edit:
You may want to disconnect battery (safety) then see if fan shaft has any bearing play, also closely inspect fan blades for damage. Could be out of balance.
Edit:
Here is a service manual which shows some adjustment but seems complicated: https://www.newtis.info/tisv2/a/en/f...ats/1VnYvvf3Wb
Bisch
Oct 31, 2022 07:00 PM
Michael Bryant
Nov 25, 2013 04:28 AM
