New cooper died at 2600 miles.
After the car started smoking, it was pulled into a parking stall. Drove it a very very short distance from the line-up to enter the car wash to the final resting place... At that point, no smoke. Car in Park, engaged the check oil level via the dash. It did it's little working icon for just a few seconds, then where you see the oil level, it said Oil pressure problem stop the engine, or something like that. To be honest the time between the low oil pressure msg and engine off there was a split second. Didn't want to leave it idle while I wrote down the exact wording. After that, I popped the hood and looked and saw nothing unusual until the pool of oil rolled across the asphalt and caused me to step back or ruin my shoes. The oil rolled out when the engine off. The oil pump was obviously off with the engine. I think the oil that rolled out was sitting on the plastic shroud that sits under the engine and where the car stopped there was a slight nose-down orientation of the car. This caused it to run off the shroud, onto the ground and at my feet. In any case, the dealer said that after the test drive yesterday and during the day today the car was still burning off a little oil. Will visit the dealership tomorrow and ask if there is a possibility of a little degreaser and steam wash. Seems to me a better way to remove oil than burning it off. Paul
I'm thinking depending on where the oil filter housing was leaking, while it was running the oil under pressure had a place to go as it circulated through out the engine and it lost oil slowly thru the leak. The moment you turned it off the oil under pressure was trapped and there is quiet a bit that is held in the housing. The system was still under pressure as the drain back bypass valve is small so the oil found the path of least resistance and started to " pour " out onto your feet and floor. I'm guessing that you had oil in the car when running and it didn't run dry albeit very low. Not taking away from any thing said above about the ext warranty. If the engine cleans up and checks out ok after the repair the ext warranty would be the way to go. Just my .02
As far as kids and cars and going away to school. I had ( they graduated now ) 2 twins sharing 1 2003 jeep grand Cherokee with 100k at univ of Albany. 4 hrs away. I didn't buy that truck for them their dad did ( I'm the happy step dad ) they put 50 k on that beast going back and fourth on breaks and such. Every time it came back home did oil change looked it over did a set of brakes I recall. When they had an issue I got a call. For instance overheating. Had them take a picture of the leak and and diagnosed that way. Showed them how to refill coolant over the phone. And get a local shop to put in a water pump. It was all I could do. It's all any of us could have done being 4 hrs away. When they broke the mirror off twice. I had it on hand on their next trip back. They suffered without it. When the blower only worked on high they lived with it and I put in a resistor when they cam back. Moral of the story. You can only do so much remotely. You can only prepare so much in advance. I showed them every thing I could for fluids and checks and tire pressures etc. and I would remind them on phone calls as they wouldn't remember or care for that matter on their own. It's the nature of kids. At the time I didn't have the cash to get them a new car for school. When they graduated and they came back home we traded in that beast for 2 brand new mazda 3's ( leases) a few months apart. . And so far so go inn fact 1 went back already and we got another one she is now paying for that one.
. The other one goes back in a little and if her job works out she'll be good to go for another one. They still live at home so now I take care of all car duties so nothing goes unchecked. In your case a previous post was for you to drive it for a while and give it your blessing. I agree with that idea. If you get them a new car what's to say or guarantee that it won't have an issue ?
Good luck and keep us posted.
Ps yes they should give you that car back spotless if nothing else it would be easier to identify any residual leak or issue if everything is clean.
Sent from my iPad using NAMotoring
Paul
Paul
Thanks for keeping us apprised, we are concerned for a number of reasons.
Can you tell us the build date of you mini?
Our MCS was born 5/08/2014
we have less than 2000 miles.
Paul
I think God needed us to be there on vacation visiting our daughter. We went because her birthday was a few days earlier, but two things occured that saturday. One was the meltdown of her Mini, which was trying for me to handle, and would have been very hard for an 18 year old to manage. Also, it melted down when she and I ran it to the carwash. Had events unfolded differently, where would she have been driving when the car failed? Secondly a friend of my daughter's experienced an unfortunate medical issue in the middle of that night. Had we not been there, there would have been no adult advocate for an 18 year old at 2 in the morning. I thank God, the higher power, random luck, or whatever YOU call it that I was on weekend get-away that weekend.
Here is a picture ( selfie never intended for the WWW so go easy ) of my daughter and I having left the hotel and midway to the car wash and happy as happy can be not knowing that the car was minutes away from meltdown.
https://www.dropbox.com/sc/v2knr5s2m...S_2m34Qt7KByfa
Paul
Paul
Paul
Dad of the year? Thanks but I don't think so, although I wouldn't mind being my kid. Would beat the heck out of being me. Ask anyone.
Being generous with your kids can teach them not to work for their own things and cause them to not to respect what they have. Time will tell if I screwed up my own kids, but if you knew them you probably wouldn't think so. I know them pretty well and the fact that they don't behave like they deserve things is exactly why I am happy to provide them. They both know that they are expected to finish school and stand on their own two feet and are on track to do just that.
Our motto here is "No Boomerangs." Once I throw them out, they aren't coming back.
Paul
Friday AM update. Went to dealership, glad it's in Irvine, not where they originally wanted the car to be serviced. The car has a problem with "sweating" a little oil. I am not familiar with the term, but found out. When the car heats up, oil that is scattered around the engine heats up and smells. To prove if the oil is from the failure of the part or new oil leaking from somewhere, they put a dye into the oil and after the car has been operation they will look for dye. No dye = car is sweating out the oil from the failure. Dye = car is leaking fresh oil after the repair. Will find out later today hopefully.
I have to compliment the young guy that Irvine Mini has running their service department. Freddy. Pleasant and seems forthright and honest. I just don't feel any hint of duplicity in my dealings with him. Hope the dealership keeps him around.
Paul
Paul
...oil that is scattered around the engine heats up and smells. To prove if the oil is from the failure of the part or new oil leaking from somewhere, they put a dye into the oil and after the car has been operation they will look for dye. No dye = car is sweating out the oil from the failure...
Thanks for the updates and hope this works out for the best. I'm in the "not a problem in the long run but they need to give you an extended warranty or something like that" camp, by the way.
Going to pick up car after work. Word is it is likely to take several hundred miles to get rid of the oil scattered about the engine. When I drove it last Friday, the car didn't smoke, but it smelled like hot burning oil. Not happy about that and also am worried about the dirt and grime that will get caught in the oil laden parts. I haven't seen the car from below so maybe it isn't all that bad under there, but will see. The entire process has not been a happy one. I think I have been well treated by everyone involved, but am not sure what Mini will do about the damage to my vehicle.
Paul
Paul
Paul
Paul
But, if the car smells like oil at operating temperature for any more than a day or two, I would be in the screaming camp. First, you shouldn't have to put up with that, they can detail the engine to get most of the oil out of there. More importantly, if there's always an oil smell, how are you supposed to tell if there's a new issue, and how long is this going to last / are you expected to put up with this?
Let's hope that between Friday and tomorrow they did more engine compartment cleaning.
If not, I'm getting in the "buy the car back and/or give me a new one" or we'll have to get a lawyer involved.
Car is home. I met the mechanic who did the repairs. He lifted the car and removed the cover under the motor. The engine is clean, but I can see how oil has seeped into the wire loom and in the nooks and crannies. He said the oil was under the car all the way back to the rear bumper. Most of the undersides were clean enough to eat off of.
The car warmed up a bit on the ride home and when in a closed garage, it stunk of oil, also got a quick wiff of it at a stoplight on the way. That will get old fast if it doesn't burn off.
Not crazy about trusting the car with my daughter in it away at college. Hopefully Mini will get me out of it so I can pick up a new one that hasn't been operated without lubricant.
Will post the final results. Has been a long and crazy journey since the problem occurred.
Thanks for your friendly advice and support.
Paul
Paul
Paul
Paul
The oil smell will go away quickly, I had a similar incident and it wasn't around more than a day or two.
People in the midwest PAY for an underside oil bath like your car got
If you look on the (somewhat odd) bright side, the car is now more corrosion proof from the salt air than ever before.
If you continue to be worried about your daughter's safety (who wouldn't), maybe the Mini isn't the right car. It sounds like you've had a lot of bad experiences with certain marques and that you are a very patient man. We've been a Toyota family for many years using the "fun" vehicles only as fair weather cars. I've logged probably close to a half million miles behind either a "T" or "L" on the steering wheel and have honestly never had any major issues whatsoever.
Maybe you can really win Dad of the year and get her a Corolla S or Scion tC as her primary car and you can keep the Mini for weekends
If you look on the (somewhat odd) bright side, the car is now more corrosion proof from the salt air than ever before.If you continue to be worried about your daughter's safety (who wouldn't), maybe the Mini isn't the right car. It sounds like you've had a lot of bad experiences with certain marques and that you are a very patient man. We've been a Toyota family for many years using the "fun" vehicles only as fair weather cars. I've logged probably close to a half million miles behind either a "T" or "L" on the steering wheel and have honestly never had any major issues whatsoever.
